跳转到主内容
Logitech UE MegaBoom Power Button Replacement
你所需要的
  1. Logitech UE MegaBoom Power Button Replacement, Outer Mesh: 步骤 1 中的图像 1,3 Logitech UE MegaBoom Power Button Replacement, Outer Mesh: 步骤 1 中的图像 2,3 Logitech UE MegaBoom Power Button Replacement, Outer Mesh: 步骤 1 中的图像 3,3
    • Locate the ends of the speaker.
    • Put a plastic opening tool in-between the rubber end and the mesh.
    • Apply a upward force in order to pry open the end.
    • Apply this procedure to the other side as well.
    • Will take force.
    • Using metal tools may permanently mar your device.
  2. Logitech UE MegaBoom Power Button Replacement: 步骤 2 中的图像 1,3 Logitech UE MegaBoom Power Button Replacement: 步骤 2 中的图像 2,3 Logitech UE MegaBoom Power Button Replacement: 步骤 2 中的图像 3,3
    • Take the Jimmy and pry up the rubber strip that has the volume buttons on it.
    • You will hear clicks as it pries up, don't worry.
    • Remove all the rubber you pried off.
  3. Logitech UE MegaBoom Power Button Replacement: 步骤 3 中的图像 1,2 Logitech UE MegaBoom Power Button Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use tweezers to lift end of plastic retainer on edge of mesh out of its channel.
    • Work the plastic retainer out of the channel all the way around the speaker.
    • Be gentle, it is easy to damage the fabric.
    • Repeat for other side.
  4. Logitech UE MegaBoom Power Button Replacement, Power Button: 步骤 4 中的图像 1,2 Logitech UE MegaBoom Power Button Replacement, Power Button: 步骤 4 中的图像 2,2
    • Locate the end of the speaker which contains the power button.
    • The circuit board which contains the power button should be visible.
    • Grasp the outer rim of this end cap and pull in an upward motion.
    • This might require some force.
  5. Logitech UE MegaBoom Power Button Replacement: 步骤 5 中的图像 1,1
    • Insert a opening tool between the circuit board and one of the black clips which is holding the board in place.
    • Using the opening tool pry up on the clip allowing the board to be freed. Pry up on the second clip to fully release the board.
    • Using your fingers lift the board out of place.
结论
另外一个人完成了本指南。
Oscar Ambriz
于09/27/17注册
958 声望
创作了6篇指南
团队
Cal Poly, Team S9-G2, Banghart Fall 2017 Cal Poly, Team S9-G2, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S9G2
4 名成员
创作了14篇指南
3条评论
Will it still be waterproof after repairing?
TechBrush - 回复
that would be a negative unless you really know what you are doing and can waterproof it
Justin Doubikin -
nice piece. i was able to follow the guide and got it right taking out the board. please where can one purchase the power button board. thanks
tony - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 19
过去 30 天: 55
总计 4,237
