跳转到主内容
Logitech UE MegaBoom Outer Mesh Replacement
你所需要的
  1. Logitech UE MegaBoom Outer Mesh Replacement, Outer Mesh: 步骤 1 中的图像 1,3 Logitech UE MegaBoom Outer Mesh Replacement, Outer Mesh: 步骤 1 中的图像 2,3 Logitech UE MegaBoom Outer Mesh Replacement, Outer Mesh: 步骤 1 中的图像 3,3
    • Locate the ends of the speaker.
    • Put a plastic opening tool in-between the rubber end and the mesh.
    • Apply a upward force in order to pry open the end.
    • Apply this procedure to the other side as well.
    • Will take force.
    • Using metal tools may permanently mar your device.
  2. Logitech UE MegaBoom Outer Mesh Replacement: 步骤 2 中的图像 1,3 Logitech UE MegaBoom Outer Mesh Replacement: 步骤 2 中的图像 2,3 Logitech UE MegaBoom Outer Mesh Replacement: 步骤 2 中的图像 3,3
    • Take the Jimmy and pry up the rubber strip that has the volume buttons on it.
    • You will hear clicks as it pries up, don't worry.
    • Remove all the rubber you pried off.
  3. Logitech UE MegaBoom Outer Mesh Replacement: 步骤 3 中的图像 1,2 Logitech UE MegaBoom Outer Mesh Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use tweezers to lift end of plastic retainer on edge of mesh out of its channel.
    • Work the plastic retainer out of the channel all the way around the speaker.
    • Be gentle, it is easy to damage the fabric.
    • Repeat for other side.
结论
另外一个人完成了本指南。
Oscar Ambriz
于09/27/17注册
958 声望
创作了6篇指南
团队
Cal Poly, Team S9-G2, Banghart Fall 2017 Cal Poly, Team S9-G2, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S9G2
4 名成员
创作了14篇指南
2条评论
You know where to buy a replacement mesh in custom colors
Jonathan Lang - 回复
Bonjour merci pour le tuto mais ou trouve t-on le “outer mesh” de remplacemet????
Merci d’avance
Evan
Evan Castione - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 19
总计 3,874
