跳转到主内容
Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement
你所需要的
  1. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Outer Mesh: 步骤 1 中的图像 1,3 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Outer Mesh: 步骤 1 中的图像 2,3 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Outer Mesh: 步骤 1 中的图像 3,3
    • Locate the ends of the speaker.
    • Put a plastic opening tool in-between the rubber end and the mesh.
    • Apply a upward force in order to pry open the end.
    • Apply this procedure to the other side as well.
    • Will take force.
    • Using metal tools may permanently mar your device.
  2. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: 步骤 2 中的图像 1,3 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: 步骤 2 中的图像 2,3 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: 步骤 2 中的图像 3,3
    • Take the Jimmy and pry up the rubber strip that has the volume buttons on it.
    • You will hear clicks as it pries up, don't worry.
    • Remove all the rubber you pried off.
  3. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: 步骤 3 中的图像 1,2 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use tweezers to lift end of plastic retainer on edge of mesh out of its channel.
    • Work the plastic retainer out of the channel all the way around the speaker.
    • Be gentle, it is easy to damage the fabric.
    • Repeat for other side.
  4. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Auxiliary Port and micro USB Port: 步骤 4 中的图像 1,3 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Auxiliary Port and micro USB Port: 步骤 4 中的图像 2,3 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Auxiliary Port and micro USB Port: 步骤 4 中的图像 3,3
    • Apply an upward force with your thumbs to loosen the end cap.
    • Grasp the end cap and lift up to seperate it from the base.
  5. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: 步骤 5 中的图像 1,3 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: 步骤 5 中的图像 2,3 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use tweezers or an opening tool to remove the plastic insert on the inside of the rubber seal.
    • Push up on the rectangular connector from the bottom to loosen the circuit board.
  6. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: 步骤 6 中的图像 1,2 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: 步骤 6 中的图像 2,2
    • Now grasp the plastic on the outside of the rubber seal and pull it out by applying an upward force.
    • Once the plastic has been removed, pull out the circuit board containing the auxiliary and USB ports.
结论
3等其他人完成本指南。
Oscar Ambriz
于09/27/17注册
958 声望
创作了6篇指南
团队
Cal Poly, Team S9-G2, Banghart Fall 2017 Cal Poly, Team S9-G2, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S9G2
4 名成员
创作了14篇指南
10条评论
How can I purchase this part being replaced thanks
Joseph Anderson - 回复
where can i get that part the whole board usb aux i need to replace due to water damage
jdw vlogs - 回复
I also need this part due to water damage. Where Do I order this entire motherboard at?
dersert6bunnie - 回复
Hello. Did you find the spare part?
Ionut -
I don’t think you can buy the parts new. Try buying a used/broken speaker for parts that has a working part that you need.
Nick Johnston - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 25
过去 30 天: 99
总计 11,523
