跳转到主内容
Logitech UE MegaBoom 3 Power Button Control Board Replacement
你所需要的
  1. Logitech UE MegaBoom 3 Power Button Control Board Replacement, General Disassembly: 步骤 1 中的图像 1,2 Logitech UE MegaBoom 3 Power Button Control Board Replacement, General Disassembly: 步骤 1 中的图像 2,2
    • To access all internal components, first flip the speaker upwards to where you can see the base.
    • Place your blue iFixit opening picks inside the gap between the speaker and the base to act as a lever when opening the speaker.
  2. Logitech UE MegaBoom 3 Power Button Control Board Replacement: 步骤 2 中的图像 1,3 Logitech UE MegaBoom 3 Power Button Control Board Replacement: 步骤 2 中的图像 2,3 Logitech UE MegaBoom 3 Power Button Control Board Replacement: 步骤 2 中的图像 3,3
    • Using the flat head #4.5 screw driver, carefully lever and rotate the driver around the edge of the speaker to enlarge the gap further.
    • Here, it is ideal to use a spudger as opposed to the flathead screwdriver, however, the flathead makes it so much easier to pry off the cap.
    • Pry off the base of the speaker and remove the end cap.
  3. Logitech UE MegaBoom 3 Power Button Control Board Replacement, Power Button Control Board: 步骤 3 中的图像 1,3 Logitech UE MegaBoom 3 Power Button Control Board Replacement, Power Button Control Board: 步骤 3 中的图像 2,3 Logitech UE MegaBoom 3 Power Button Control Board Replacement, Power Button Control Board: 步骤 3 中的图像 3,3
    • Take off the fiber cover by prying it from the top of the speaker using the flathead 4.5 mm screwdriver.
    • After the cover is loosened, the cap can finally be pulled off.
  4. Logitech UE MegaBoom 3 Power Button Control Board Replacement: 步骤 4 中的图像 1,3 Logitech UE MegaBoom 3 Power Button Control Board Replacement: 步骤 4 中的图像 2,3 Logitech UE MegaBoom 3 Power Button Control Board Replacement: 步骤 4 中的图像 3,3
    • Remove the top half of the speaker using the 4.5 mm flat head screwdriver.
    • Now remove the top of the speaker by prying and releasing the tab around the cap using the same screwdriver.
  5. Logitech UE MegaBoom 3 Power Button Control Board Replacement: 步骤 5 中的图像 1,3 Logitech UE MegaBoom 3 Power Button Control Board Replacement: 步骤 5 中的图像 2,3 Logitech UE MegaBoom 3 Power Button Control Board Replacement: 步骤 5 中的图像 3,3
    • With the cap removed, using Phillips #0 screwdriver remove all four 2.0 mm screws to take off the control board.
    • Now you can replace the power button control board.
结论
2等其他人完成本指南。
Anthony Miles
于09/04/23注册
1,021 声望
创作了6篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 72
总计 568
