跳转到主内容
Logitech UE Boombox Bluetooth Adapter Replacement
你所需要的
  1. Logitech UE Boombox Bluetooth Adapter Replacement, Speaker Grille: 步骤 1 中的图像 1,2 Logitech UE Boombox Bluetooth Adapter Replacement, Speaker Grille: 步骤 1 中的图像 2,2
    • Use a metal spudger to pry open the power button cover.
    • Once the power button cover is slightly opened, use your fingers to remove the power button cover.
  2. Logitech UE Boombox Bluetooth Adapter Replacement: 步骤 2 中的图像 1,3 Logitech UE Boombox Bluetooth Adapter Replacement: 步骤 2 中的图像 2,3 Logitech UE Boombox Bluetooth Adapter Replacement: 步骤 2 中的图像 3,3
    • Press firmly on the end of the latch and pull the two-wire connector away from the base to separate.
  3. Logitech UE Boombox Bluetooth Adapter Replacement: 步骤 3 中的图像 1,3 Logitech UE Boombox Bluetooth Adapter Replacement: 步骤 3 中的图像 2,3 Logitech UE Boombox Bluetooth Adapter Replacement: 步骤 3 中的图像 3,3
    • Firmly press on the end of the latch and pull the four-wire connector away from the base to separate.
  4. Logitech UE Boombox Bluetooth Adapter Replacement: 步骤 4 中的图像 1,3 Logitech UE Boombox Bluetooth Adapter Replacement: 步骤 4 中的图像 2,3 Logitech UE Boombox Bluetooth Adapter Replacement: 步骤 4 中的图像 3,3
    • Lightly, pry up on each side of the black band connector lock using your fingertips.
    • Once unlocked, pull straight up on the connector to remove.
  5. Logitech UE Boombox Bluetooth Adapter Replacement: 步骤 5 中的图像 1,2 Logitech UE Boombox Bluetooth Adapter Replacement: 步骤 5 中的图像 2,2
    • Remove the five black 14mm Phillips #2 screws from the black plastic side panel.
    • Remove the one silver 16mm Phillips #2 screws from the black plastic side panel.
    • Remove the black plastic screw panel from the boombox.
  6. Logitech UE Boombox Bluetooth Adapter Replacement: 步骤 6 中的图像 1,2 Logitech UE Boombox Bluetooth Adapter Replacement: 步骤 6 中的图像 2,2
    • On the opposite side of the device, pry open the volume rocker with a metal spudger.
    • Remove the panel with your fingers once the volume rocker is slightly opened.
  7. Logitech UE Boombox Bluetooth Adapter Replacement: 步骤 7 中的图像 1,3 Logitech UE Boombox Bluetooth Adapter Replacement: 步骤 7 中的图像 2,3 Logitech UE Boombox Bluetooth Adapter Replacement: 步骤 7 中的图像 3,3
    • Remove the one silver16 mm Phillips #2 screw from the black plastic side panel.
    • Once all screws are removed, take the screw panel out of the device to gain access to the back of the panel.
  8. Logitech UE Boombox Bluetooth Adapter Replacement: 步骤 8 中的图像 1,2 Logitech UE Boombox Bluetooth Adapter Replacement: 步骤 8 中的图像 2,2
    • Firmly press on the end of the latch and pull the two-wire connector away from the base.
  9. Logitech UE Boombox Bluetooth Adapter Replacement: 步骤 9 中的图像 1,2 Logitech UE Boombox Bluetooth Adapter Replacement: 步骤 9 中的图像 2,2
    • Pull up on the aluminum boombox handle to remove.
  10. Logitech UE Boombox Bluetooth Adapter Replacement: 步骤 10 中的图像 1,2 Logitech UE Boombox Bluetooth Adapter Replacement: 步骤 10 中的图像 2,2
    • Use a metal spudger to pry the rubber base apart from the aluminum grille.
  11. Logitech UE Boombox Bluetooth Adapter Replacement: 步骤 11 中的图像 1,2 Logitech UE Boombox Bluetooth Adapter Replacement: 步骤 11 中的图像 2,2
    • Pull the rubber base away from the boombox.
  12. Logitech UE Boombox Bluetooth Adapter Replacement: 步骤 12 中的图像 1,1
    • Remove the four black 7.5mm Phillips #2 screws on each side of the device.
    • There should be a total of eight screws removed in this step.
  13. Logitech UE Boombox Bluetooth Adapter Replacement: 步骤 13 中的图像 1,3 Logitech UE Boombox Bluetooth Adapter Replacement: 步骤 13 中的图像 2,3 Logitech UE Boombox Bluetooth Adapter Replacement: 步骤 13 中的图像 3,3
    • Pull vertically on the speaker grille to remove it from the boombox.
  14. Logitech UE Boombox Bluetooth Adapter Replacement, Bluetooth Adapter: 步骤 14 中的图像 1,3 Logitech UE Boombox Bluetooth Adapter Replacement, Bluetooth Adapter: 步骤 14 中的图像 2,3 Logitech UE Boombox Bluetooth Adapter Replacement, Bluetooth Adapter: 步骤 14 中的图像 3,3
    • Remove the fifteen 13.0mm Phillips #2 screws from the side of the device containing two speakers.
    • Separate the two halves by gently pulling them apart.
    • The screws at this step are embedded deep within the device so make sure your screwdriver is long.
  15. Logitech UE Boombox Bluetooth Adapter Replacement: 步骤 15 中的图像 1,3 Logitech UE Boombox Bluetooth Adapter Replacement: 步骤 15 中的图像 2,3 Logitech UE Boombox Bluetooth Adapter Replacement: 步骤 15 中的图像 3,3
    • Pull up on the lock connecting the band connector to the motherboard with your finger tips.
    • Detach the band connector gently from the motherboard.
  16. Logitech UE Boombox Bluetooth Adapter Replacement: 步骤 16 中的图像 1,1
    • Remove the five black 7.0mm Phillips #2 screws.
  17. Logitech UE Boombox Bluetooth Adapter Replacement: 步骤 17 中的图像 1,1
    • Move the motherboard away from bluetooth adapter gently.
    • Remove two 7.0mm Phillips #2 screws.
    • Motherboard will still be attached to device.
  18. Logitech UE Boombox Bluetooth Adapter Replacement: 步骤 18 中的图像 1,1
    • Remove the bluetooth adapter from the boombox.
结论
teresa ahmadyar
于10/06/16注册
101 声望
撰写一个指南
团队
CSU Fullerton, Team 1-1, Bruce Fall 2016 CSU Fullerton, Team 1-1, Bruce Fall 2016 的会员
CSUF-BRUCE-F16S1G1
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 9
总计 1,617
