跳转到主内容
加入维修社区 - 创建账户
Logitech UE Boom Motherboard Replacement
你所需要的
  1. Logitech UE Boom Motherboard Replacement, D-ring: 步骤 1 中的图像 1,1
    • Turn the device over. The D-ring will be on the left face of the speaker when viewing the device from this orientation.
    询问修复机器人
  2. Logitech UE Boom Motherboard Replacement: 步骤 2 中的图像 1,2 Logitech UE Boom Motherboard Replacement: 步骤 2 中的图像 2,2
    • Lift the handle on the D-ring and unscrew it.
    • Remove the D-ring.
    询问修复机器人
  3. Logitech UE Boom Motherboard Replacement, Bluetooth Adapter: 步骤 3 中的图像 1,1
    • Any repairs made from this point forward will void your device's warranty.
    • Holding the speaker upright, wedge the metal spudger in between the casing and the speaker. Gently pry open the tabs as they are easily broken.
  4. Logitech UE Boom Motherboard Replacement: 步骤 4 中的图像 1,3 Logitech UE Boom Motherboard Replacement: 步骤 4 中的图像 2,3 Logitech UE Boom Motherboard Replacement: 步骤 4 中的图像 3,3
    • Find the part of the casing that covers the volume controls. Wedge the metal spudger under this and pry open all of the tabs as in the previous step.
    • Repeat for the bottom of the speaker and pry the casing open with your fingers.
    询问修复机器人
  5. Logitech UE Boom Motherboard Replacement: 步骤 5 中的图像 1,2 Logitech UE Boom Motherboard Replacement: 步骤 5 中的图像 2,2
    • Using the Phillips J0 head screwdriver, unscrew the four silver 9 mm screws.
    • Do the same for the two black 7 mm screws.
  6. Logitech UE Boom Motherboard Replacement: 步骤 6 中的图像 1,3 Logitech UE Boom Motherboard Replacement: 步骤 6 中的图像 2,3 Logitech UE Boom Motherboard Replacement: 步骤 6 中的图像 3,3
    • This next step involves the use of a hot soldering iron. Remember to be careful during this step since it can be easy to burn yourself.
    • Using a soldering iron, de-solder the two ends of the switch plate. Desolder the two terminals on headphone jack side first, as the middle connection is notched and should be slid out when molten.
  7. Logitech UE Boom Motherboard Replacement: 步骤 7 中的图像 1,1
    • With the switch plate disconnected, remove it and your device should now look like this.
    询问修复机器人
  8. Logitech UE Boom Motherboard Replacement, Lithium Battery: 步骤 8 中的图像 1,1
    • With a metal spudger, pry open the tabs on the speaker sleeve along the length of the speaker.
    询问修复机器人
  9. Logitech UE Boom Motherboard Replacement: 步骤 9 中的图像 1,1
    • Use a plastic opening tool to pry the sleeve off from the bottom of the speaker.
  10. Logitech UE Boom Motherboard Replacement: 步骤 10 中的图像 1,3 Logitech UE Boom Motherboard Replacement: 步骤 10 中的图像 2,3 Logitech UE Boom Motherboard Replacement: 步骤 10 中的图像 3,3
    • Peel off the sleeve.
    询问修复机器人
  11. Logitech UE Boom Motherboard Replacement: 步骤 11 中的图像 1,2 Logitech UE Boom Motherboard Replacement: 步骤 11 中的图像 2,2
    • Use a Phillips 1 screwdriver to unscrew the eight black 14 mm screws along the length of the casing.
    询问修复机器人
  12. Logitech UE Boom Motherboard Replacement: 步骤 12 中的图像 1,2 Logitech UE Boom Motherboard Replacement: 步骤 12 中的图像 2,2
    • With the screws removed, pry open the casing to be able to get to the components inside.
    • Try prying the case open from one of the ends if that is easier.
    询问修复机器人
  13. Logitech UE Boom Motherboard Replacement: 步骤 13 中的图像 1,2 Logitech UE Boom Motherboard Replacement: 步骤 13 中的图像 2,2
    • With a Phillips #00 screwdriver, unscrew two 5.6 mm screws from the rectangular shaped circuit board.
    询问修复机器人
  14. Logitech UE Boom Motherboard Replacement: 步骤 14 中的图像 1,1
    • With the Phillips #2 screwdriver, unscrew the 9.9 mm screw from the larger circuit board surrounding the speaker.
    询问修复机器人
  15. Logitech UE Boom Motherboard Replacement: 步骤 15 中的图像 1,1
    • Once all of the screws are gone, you should be able to remove the circuit boards and find the battery.
    询问修复机器人
  16. Logitech UE Boom Motherboard Replacement: 步骤 16 中的图像 1,2 Logitech UE Boom Motherboard Replacement: 步骤 16 中的图像 2,2
    • Remove the battery by pulling it from the terminal as marked in the picture.
    询问修复机器人
  17. Logitech UE Boom Motherboard Replacement, Motherboard: 步骤 17 中的图像 1,2 Logitech UE Boom Motherboard Replacement, Motherboard: 步骤 17 中的图像 2,2
    • Remove the speaker by pulling it from the terminal as marked in the picture.
    询问修复机器人
  18. Logitech UE Boom Motherboard Replacement: 步骤 18 中的图像 1,2 Logitech UE Boom Motherboard Replacement: 步骤 18 中的图像 2,2
    • Remove the second speaker by pulling it from the terminal as marked in the picture.
    询问修复机器人
  19. Logitech UE Boom Motherboard Replacement: 步骤 19 中的图像 1,2 Logitech UE Boom Motherboard Replacement: 步骤 19 中的图像 2,2
    • Finally, remove the motherboard completely by pulling it from the terminal as marked in the picture.
    询问修复机器人
结论
7等其他人完成本指南。
Sean Reilly
于10/01/15注册
1,772 声望
创作了2篇指南
团队
Cal Poly, Team 4-1, Maness Fall 2015 Cal Poly, Team 4-1, Maness Fall 2015 的会员
CPSU-MANESS-F15S4G1
4 名成员
创作了22篇指南
2指南评论
Is there anywhere I can buy the motherboard to replace my UE Boom board fried by lightning?
Mohd Razali Hamid - 回复 分享
I would like to know where can I buy the UE BOOM Mother Board.
許志豪 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 17
过去 30 天: 109
总计 11,059
