跳转到主内容
Logitech UE Boom Lithium Battery Replacement
你所需要的
  1. Logitech UE Boom Lithium Battery Replacement, D-ring: 步骤 1 中的图像 1,1
    • Turn the device over. The D-ring will be on the left face of the speaker when viewing the device from this orientation.
  2. Logitech UE Boom Lithium Battery Replacement: 步骤 2 中的图像 1,2 Logitech UE Boom Lithium Battery Replacement: 步骤 2 中的图像 2,2
    • Lift the handle on the D-ring and unscrew it.
    • Remove the D-ring.
  3. Logitech UE Boom Lithium Battery Replacement, Bluetooth Adapter: 步骤 3 中的图像 1,1
    • Any repairs made from this point forward will void your device's warranty.
    • Holding the speaker upright, wedge the metal spudger in between the casing and the speaker. Gently pry open the tabs as they are easily broken.
  4. Logitech UE Boom Lithium Battery Replacement: 步骤 4 中的图像 1,3 Logitech UE Boom Lithium Battery Replacement: 步骤 4 中的图像 2,3 Logitech UE Boom Lithium Battery Replacement: 步骤 4 中的图像 3,3
    • Find the part of the casing that covers the volume controls. Wedge the metal spudger under this and pry open all of the tabs as in the previous step.
    • Repeat for the bottom of the speaker and pry the casing open with your fingers.
  5. Logitech UE Boom Lithium Battery Replacement: 步骤 5 中的图像 1,2 Logitech UE Boom Lithium Battery Replacement: 步骤 5 中的图像 2,2
    • Using the Phillips J0 head screwdriver, unscrew the four silver 9 mm screws.
    • Do the same for the two black 7 mm screws.
  6. Logitech UE Boom Lithium Battery Replacement: 步骤 6 中的图像 1,3 Logitech UE Boom Lithium Battery Replacement: 步骤 6 中的图像 2,3 Logitech UE Boom Lithium Battery Replacement: 步骤 6 中的图像 3,3
    • This next step involves the use of a hot soldering iron. Remember to be careful during this step since it can be easy to burn yourself.
    • Using a soldering iron, de-solder the two ends of the switch plate. Desolder the two terminals on headphone jack side first, as the middle connection is notched and should be slid out when molten.
  7. Logitech UE Boom Lithium Battery Replacement: 步骤 7 中的图像 1,1
    • With the switch plate disconnected, remove it and your device should now look like this.
  8. Logitech UE Boom Lithium Battery Replacement, Lithium Battery: 步骤 8 中的图像 1,1
    • With a metal spudger, pry open the tabs on the speaker sleeve along the length of the speaker.
  9. Logitech UE Boom Lithium Battery Replacement: 步骤 9 中的图像 1,1
    • Use a plastic opening tool to pry the sleeve off from the bottom of the speaker.
  10. Logitech UE Boom Lithium Battery Replacement: 步骤 10 中的图像 1,3 Logitech UE Boom Lithium Battery Replacement: 步骤 10 中的图像 2,3 Logitech UE Boom Lithium Battery Replacement: 步骤 10 中的图像 3,3
    • Peel off the sleeve.
  11. Logitech UE Boom Lithium Battery Replacement: 步骤 11 中的图像 1,2 Logitech UE Boom Lithium Battery Replacement: 步骤 11 中的图像 2,2
    • Use a Phillips 1 screwdriver to unscrew the eight black 14 mm screws along the length of the casing.
  12. Logitech UE Boom Lithium Battery Replacement: 步骤 12 中的图像 1,2 Logitech UE Boom Lithium Battery Replacement: 步骤 12 中的图像 2,2
    • With the screws removed, pry open the casing to be able to get to the components inside.
    • Try prying the case open from one of the ends if that is easier.
  13. Logitech UE Boom Lithium Battery Replacement: 步骤 13 中的图像 1,2 Logitech UE Boom Lithium Battery Replacement: 步骤 13 中的图像 2,2
    • With a Phillips #00 screwdriver, unscrew two 5.6 mm screws from the rectangular shaped circuit board.
  14. Logitech UE Boom Lithium Battery Replacement: 步骤 14 中的图像 1,1
    • With the Phillips #2 screwdriver, unscrew the 9.9 mm screw from the larger circuit board surrounding the speaker.
  15. Logitech UE Boom Lithium Battery Replacement: 步骤 15 中的图像 1,1
    • Once all of the screws are gone, you should be able to remove the circuit boards and find the battery.
  16. Logitech UE Boom Lithium Battery Replacement: 步骤 16 中的图像 1,2 Logitech UE Boom Lithium Battery Replacement: 步骤 16 中的图像 2,2
    • Remove the battery by pulling it from the terminal as marked in the picture.
结论
33等其他人完成本指南。
Jose Cruz Arinaga
于10/01/15注册
1,022 声望
创作了3篇指南
团队
Cal Poly, Team 4-1, Maness Fall 2015 Cal Poly, Team 4-1, Maness Fall 2015 的会员
CPSU-MANESS-F15S4G1
4 名成员
创作了22篇指南
30指南评论
What battery is required?
Harrison Leavey - 回复
You've got to be joking - so you spend £100 on a speaker and then need a degree in electrical engineering to replace the battery - what a load of s***e
Kevin Reitze - 回复
exactly, I agree
lisamuehlum -
I replaced the battery in mine. It took about an hour and it was easy, while the instructions appear complicated, undoing a few screws and folding back some tabs took only a few seconds. Before I replaced the battery my Boom had failed completely. Nothing I tried kicked the dead battery into working again, so I had two choices. Try replacing the battery or chucking it in the bin. So I bought a battery and had a go. I read up and had the right tools, and as luck favours the prepared, I was successful. The only warning I can think of is that out of the box the Boom is water resistant I believe, but post repair, I doubt it’s water resistant now.
Brandon Cheshire -
Don't pry open the entire thing. Open the side with the d-ring, there should be 4 screws like in the pic above and access to battery directly under that. There's instructions for changing battery in the box.
Brian Blackford - 回复
添加评论
浏览统计数据:
过去 24 小时: 44
过去 7 天: 359
过去 30 天: 1,093
总计 139,214
