跳转到主内容
加入维修社区 - 创建账户
Logitech UE Boom Bluetooth Adapter Replacement
你所需要的
  1. Logitech UE Boom Bluetooth Adapter Replacement, D-ring: 步骤 1 中的图像 1,1
    • Turn the device over. The D-ring will be on the left face of the speaker when viewing the device from this orientation.
    询问修复机器人
    添加评论
  2. Logitech UE Boom Bluetooth Adapter Replacement: 步骤 2 中的图像 1,2 Logitech UE Boom Bluetooth Adapter Replacement: 步骤 2 中的图像 2,2
    • Lift the handle on the D-ring and unscrew it.
    • Remove the D-ring.
    询问修复机器人
    添加评论
  3. Logitech UE Boom Bluetooth Adapter Replacement, Bluetooth Adapter: 步骤 3 中的图像 1,1
    • Any repairs made from this point forward will void your device's warranty.
    • Holding the speaker upright, wedge the metal spudger in between the casing and the speaker. Gently pry open the tabs as they are easily broken.
    添加评论
  4. Logitech UE Boom Bluetooth Adapter Replacement: 步骤 4 中的图像 1,3 Logitech UE Boom Bluetooth Adapter Replacement: 步骤 4 中的图像 2,3 Logitech UE Boom Bluetooth Adapter Replacement: 步骤 4 中的图像 3,3
    • Find the part of the casing that covers the volume controls. Wedge the metal spudger under this and pry open all of the tabs as in the previous step.
    • Repeat for the bottom of the speaker and pry the casing open with your fingers.
    询问修复机器人
    添加评论
  5. Logitech UE Boom Bluetooth Adapter Replacement: 步骤 5 中的图像 1,2 Logitech UE Boom Bluetooth Adapter Replacement: 步骤 5 中的图像 2,2
    • Using the Phillips J0 head screwdriver, unscrew the four silver 9 mm screws.
    • Do the same for the two black 7 mm screws.
    添加评论
  6. Logitech UE Boom Bluetooth Adapter Replacement: 步骤 6 中的图像 1,3 Logitech UE Boom Bluetooth Adapter Replacement: 步骤 6 中的图像 2,3 Logitech UE Boom Bluetooth Adapter Replacement: 步骤 6 中的图像 3,3
    • This next step involves the use of a hot soldering iron. Remember to be careful during this step since it can be easy to burn yourself.
    • Using a soldering iron, de-solder the two ends of the switch plate. Desolder the two terminals on headphone jack side first, as the middle connection is notched and should be slid out when molten.
    添加评论
  7. Logitech UE Boom Bluetooth Adapter Replacement: 步骤 7 中的图像 1,1
    • With the switch plate disconnected, remove it and your device should now look like this.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
7等其他人完成本指南。
团队
Cal Poly, Team 4-1, Maness Fall 2015 Cal Poly, Team 4-1, Maness Fall 2015 的会员
CPSU-MANESS-F15S4G1
4 名成员
创作了22篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 30
过去 30 天: 111
总计 12,385
