跳转到主内容
Logitech Spotlight Battery Replacement
你所需要的
  1. Logitech Spotlight Battery Replacement, Removing the back cover: 步骤 1 中的图像 1,2 Logitech Spotlight Battery Replacement, Removing the back cover: 步骤 1 中的图像 2,2
    • Removing the back cover :
    • The back cover is gluded on back middle and lower side. So it's much easier to rub in from top edge.
  2. Logitech Spotlight Battery Replacement, Desoldering the wire of the battery: 步骤 2 中的图像 1,3 Logitech Spotlight Battery Replacement, Desoldering the wire of the battery: 步骤 2 中的图像 2,3 Logitech Spotlight Battery Replacement, Desoldering the wire of the battery: 步骤 2 中的图像 3,3
    • Try to tick out the wire of the battery to get more space.
    • Cut out the yellow tape of battery.
    • Desoldering the two wires connecting the battery to the board. Carefully don't touch the the positive and negative terminals on the same time for security.
  3. Logitech Spotlight Battery Replacement, Pull out the battery: 步骤 3 中的图像 1,1
    • Use pliers to clamp the board on the battery and pull the battery out. The battery is glued on the mainboard, and the battery is too long for back hole. So it's no easy to pull out.
  4. Logitech Spotlight Battery Replacement, Solder the new battery: 步骤 4 中的图像 1,2 Logitech Spotlight Battery Replacement, Solder the new battery: 步骤 4 中的图像 2,2
    • The original battery size is 3.9mm x 8mm x 36 mm. For ease of installation, I get a smaller battery with size 3.5mm x 8mm x 29 mm.
    • Put the new battery into the battery hole, and solder the new battery wires with the original wires. And use polyimide tape to cover the wiring point for safety .
  5. Logitech Spotlight Battery Replacement, Cover back the back cover: 步骤 5 中的图像 1,1
    • Clear out the original clue on the two sides and put some clue on. Then Cover back the back cover.
结论
Leo Hsi
于08/09/24注册
121 声望
撰写一个指南
1指南评论
Potresti indicare tipo di batteria e dove comprarla? grazie
Sandro - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 33
总计 522
