跳转到主内容
Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement
你所需要的
  1. Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement, Dock Adapter Cover: 步骤 1 中的图像 1,3 Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement, Dock Adapter Cover: 步骤 1 中的图像 2,3 Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement, Dock Adapter Cover: 步骤 1 中的图像 3,3
    • To remove the plastic cover, use the plastic opening tool at the corner of the device.
    • Then insert the metal spudger in the opening and slowly move the metal spudger along all sides of the cover.
    • Caution: Metal spudger can damage the internal components of the device such as the motherboard. Make sure to use the metal spudger carefully to avoid any unnecessary damages.
    • Make sure the metal supdger is inserted deep enough as the cover is glued to the device.
    • Caution: Carefully remove the cover as it is easy to break.
  2. Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: 步骤 2 中的图像 1,2 Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: 步骤 2 中的图像 2,2
    • Remove the eight 10.5 mm Phillips #1 screws securing the cover.
    • Remove three 5.2 mm Philips #1 screws securing the dock.
  3. Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: 步骤 3 中的图像 1,2 Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: 步骤 3 中的图像 2,2
    • Use the metal spudger to loosen the front cover to get into the inner part of the device.
    • Metal spudger can damage the internal components of the device such as the motherboard. Make sure to use the metal spudger carefully to avoid any unnecessary damages.
    • Make sure to carefully lift up the front cover from the back cover.
    • There are wires connecting to between battery and the cover.
  4. Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: 步骤 4 中的图像 1,2 Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: 步骤 4 中的图像 2,2
    • Identify the small circuit board attached to the dock adapter cover.
    • remove two 2.5 mm Phillips #1 screws at the circuit board.
  5. Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: 步骤 5 中的图像 1,2 Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: 步骤 5 中的图像 2,2
    • Carefully take out the dock adapter cover from the device.
    • It might needs few try to pull out the small circuit board.
    • Take out the broken dock adapter cover and replace with the new one.
结论
ali alhashim
于07/18/18注册
121 声望
撰写一个指南
团队
IUPUI, Team S4-G4, Wilson Summer 2018 IUPUI, Team S4-G4, Wilson Summer 2018 的会员
IUPUI-WILSON-SU18S4G4
4 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 842
