跳转到主内容
加入维修社区 - 创建账户
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
Logitech Performance MX Left Click Repair
你所需要的
  1. Logitech Performance MX Left Click Repair, Turn off the mouse and remove the battery: 步骤 1 中的图像 1,1
    • On the back of the mouse, slide the power switch so that the red area is showing to turn off the mouse. Pry open the panel on the bottom to remove the battery.
    询问修复机器人
    添加评论
  2. Logitech Performance MX Left Click Repair, Remove the 3 pads: 步骤 2 中的图像 1,1
    • To access the screws necessary to open the mouse, you must remove the pads on the bottom of the mouse. Use a sharp tool such as an iFixit Jimmy tool or an X-acto knife to separate the pad from the case. Each pad has two layers. Ideally, both should remain attached, but this is hard to achieve.
    询问修复机器人
    添加评论
  3. Logitech Performance MX Left Click Repair, Remove the 4 screws: 步骤 3 中的图像 1,1
    • Use a 00 Phillips-Head screwdriver to remove the screws at the bottom of the mouse.
    询问修复机器人
    添加评论
  4. Logitech Performance MX Left Click Repair, Remove the upper part of the mouse: 步骤 4 中的图像 1,3 Logitech Performance MX Left Click Repair, Remove the upper part of the mouse: 步骤 4 中的图像 2,3 Logitech Performance MX Left Click Repair, Remove the upper part of the mouse: 步骤 4 中的图像 3,3
    • Slide the bottom laterally while lifting.
    询问修复机器人
    添加评论
  5. Logitech Performance MX Left Click Repair, (optional) remove the connector: 步骤 5 中的图像 1,1
    • This step isn't necessary, but it makes it easier to work on the mouse.
    询问修复机器人
    添加评论
  6. Logitech Performance MX Left Click Repair, (optional) put a bit of tape on top of the microswitch: 步骤 6 中的图像 1,1
    • This helps to avoid losing the white piece.
    询问修复机器人
    添加评论
  7. Logitech Performance MX Left Click Repair, Remove the multiswitch top: 步骤 7 中的图像 1,2 Logitech Performance MX Left Click Repair, Remove the multiswitch top: 步骤 7 中的图像 2,2
    • Use your spudger to push the vertical front part of the multiswitch outwards to unhook the top part of the switch casing.
    询问修复机器人
    添加评论
  8. Logitech Performance MX Left Click Repair, Flatten the metallic piece: 步骤 8 中的图像 1,2 Logitech Performance MX Left Click Repair, Flatten the metallic piece: 步骤 8 中的图像 2,2
    • Flatten the metallic piece of the multiswitch (it will probably be curved upward) until you get a neat "click" sound.
    询问修复机器人
    添加评论
结论
To reassemble the mouse, follow the instructions in the reverse order.
取消:我没有完成这个指南。
12等其他人完成本指南。
由衷感谢以下译者:
fr en
94%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Samuel Colin
于03/26/20注册
717 声望
创作了2篇指南
8指南评论
merci , ca vient de sauver ma Revolution
Clement Renaut - 回复 分享
Avec plaisir. J'en suis ravi :)
Samuel Colin - 回复 分享
Thank you, this worked flawlessly. Your time and effort is well appreciated.
Kenji Lum - 回复 分享
Thank you so much. My left click often unregisters incorrectly. If not for step 7 and 8, I wouldn't have opened the multiswitch top and clean the contact point. Seems to work perfectly normal now. It'd be a waste to throw away the whole item just because of a tiny defective component. Thanks again for helping me fixed it.
Thuan Chau - 回复 分享
@Kenji @thuan: I'm glad I could help. Thanks for your comments!
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 56
过去 30 天: 220
总计 25,631
