跳转到主内容
Logitech POP Mouse Battery Replacement
  1. Logitech POP Mouse Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the mouse over so the bottom is facing up.
    • Slide the power switch off.
    • Make sure that the plate behind the switch is red so that you know it's off.
  2. Logitech POP Mouse Battery Replacement: 步骤 2 中的图像 1,1
    • Flip the mouse back over so it is facing upright.
    • Press gently on the white button and pull towards the bottom of the mouse to pull the top cover off.
  3. Logitech POP Mouse Battery Replacement: 步骤 3 中的图像 1,1
    • Press down on the part of the battery closest to the front of the mouse to pop the backend of it upwards, and then gently pull the battery out.
  4. Logitech POP Mouse Battery Replacement: 步骤 4 中的图像 1,1
    • Insert the battery into the slot.
    • The battery compartment has a sticker to remind you which direction the battery needs to face.
    • Place the cover plate over the mouse, and the magnetic connectors should slide the cover into place.
  5. Logitech POP Mouse Battery Replacement: 步骤 5 中的图像 1,1
    • Turn your mouse back on using the same switch as earlier. If everything was done correctly, your mouse should be good as new!
终点
CoffeeAndE
于03/05/25注册
121 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 22
过去 30 天: 99
总计 664
