简介
1- Remove the cover where you replace the battery.
2 - Below each battery, there is a screw that you remove with a small Philips screwdriver.
3 - At the top of the back part of the mouse there are two rubber finishes that you remove (it has an adhesive) and there you will find the screws that hold the top.
4 - It gets loose immediately, please be careful with the wire that connects one part to another, please disconnect this wire.
你所需要的
另外一个人完成了本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
