跳转到主内容
Logitech MX Master 3 for Business Mouse Feet Replacement
你所需要的
  1. Logitech MX Master 3 for Business Mouse Feet Replacement, Soften the mouse feet adhesive: 步骤 1 中的图像 1,3 Logitech MX Master 3 for Business Mouse Feet Replacement, Soften the mouse feet adhesive: 步骤 1 中的图像 2,3 Logitech MX Master 3 for Business Mouse Feet Replacement, Soften the mouse feet adhesive: 步骤 1 中的图像 3,3
    • Flip the mouse's power switch into the OFF position, unplug any cables, and flip it over so the feet are facing up.
    • The unique shape of some mice can prevent them from laying flat. If you need to, lay your mouse on a soft towel to prevent wobble.
    • If you're planning to reuse your existing mouse feet, note that the adhesive needs to be thoroughly heated for them to be cleanly removed.
    • Heat an iOpener and apply it to each of the mouse feet for about one minute each.
    • Alternatively, you can use a hair dryer to soften the mouse feet adhesive.
    • When using a hair dryer, don't heat the feet for more than a couple seconds at a time—anything hotter than just warm to the touch risks melting or warping the plastic lower case.
    • The information sticker adhesive may soften during this step, but you don't need to remove it.
  2. Logitech MX Master 3 for Business Mouse Feet Replacement, Separate the mouse foot adhesive: 步骤 2 中的图像 1,3 Logitech MX Master 3 for Business Mouse Feet Replacement, Separate the mouse foot adhesive: 步骤 2 中的图像 2,3 Logitech MX Master 3 for Business Mouse Feet Replacement, Separate the mouse foot adhesive: 步骤 2 中的图像 3,3
    • Slide an opening pick under an edge of the left mouse foot.
    • Go slowly, and make sure the pick slides underneath both the foot and its adhesive pad. These layers separate easily.
    • If you plan on reusing your mouse feet, be careful not to crease them or separate them from their adhesive pads.
    • If the foot feels stuck, apply more heat before continuing.
    • Slide your pick under the foot to separate its adhesive until you can grab it with your fingers.
    • Peel up and remove the left mouse foot.
  3. Logitech MX Master 3 for Business Mouse Feet Replacement, Remove the right and rear mouse feet: 步骤 3 中的图像 1,2 Logitech MX Master 3 for Business Mouse Feet Replacement, Remove the right and rear mouse feet: 步骤 3 中的图像 2,2
    • Repeat the previous two steps to remove the right and the rear mouse feet.
  4. Logitech MX Master 3 for Business Mouse Feet Replacement, Reassembly information: 步骤 4 中的图像 1,3 Logitech MX Master 3 for Business Mouse Feet Replacement, Reassembly information: 步骤 4 中的图像 2,3 Logitech MX Master 3 for Business Mouse Feet Replacement, Reassembly information: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • If the adhesive separated from the foot:
    • Slide the flat end of a spudger under an edge of the adhesive. If the adhesive seems stuck, you may need to heat the adhesive further.
    • Use a pair of tweezers or a spudger to remove any large chunks of leftover adhesive.
    • For installing new mouse feet or reusing your old ones:
    • Thoroughly clean the bottom of the mouse with isopropyl alcohol and a lint-free of microfiber cloth. Allow the surface to dry completely.
    • Peel your new mouse feet away from their adhesive liners and press them firmly into place.
  5. Logitech MX Master 3 for Business Mouse Feet Replacement, Remove the front mouse foot: 步骤 5 中的图像 1,1
    • Remove the front mouse foot.
结论
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Clay Eickemeyer
于09/19/22注册
67,312 声望
创作了453篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,430篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 13
总计 344
