简介
If scrolling the scroll wheel starts becoming imprecise or seemingly "slow", it may be because there's filth accumulation affecting the movement sensor. Because of the rolling movement of the wheel, dust accumulates in the form of a ball and will block the photo-sensor intermittently. There's some discussion on the internet that may lead us to think that this behavior is an app configuration problem (if you're using Logitech Options), but after opening the device I confirmed that, in my case, it was just dirty. Please note that you just have to disassemble the device using the instructions you will find right here on iFixit up until step #2 of the Disassembly Guide to reach the scroll wheel, so you may skip steps #3-#11 of the guide below.
你所需要的
The right click lever comes out after the bracket covering the ribbon cable
The Right click lever comes out through the front/top of the mouse
Then the circuit boards can be removed
Under the circuit boards there is three piece that need to come out next
The first has one screw and two clear pieces that transmit the light from the circuit board to the outside of the mouse and hole to allow another to pass through it
Then the computer selector switch lever can come out the front/top of the mouse
After that the connecting light indicator transmitter will fall out and the left click lever can be removed
With the cover open, look at the scroll wheel on the side that has a hollow central area and roll the wheel. You should look for any dirt/filth that may have accumulated on this inner side of the wheel in the form of a little ball that interferes with the sensors (see image on next step).
一条评论
Before going to all that work, I tried using a can of air to forcefully blow into the gap on each side of the scroll wheel. I don't know if it got any lint out, but it started working perfectly again without having to disassemble it.
