跳转到主内容
Logitech MX Anywhere 2 Right Click Switch Replacement
你所需要的
    • First Remove the Mouse Skates. Then removes the 4 screws underneath.
    • Take the Cover off.
    • Then take all the screws out remove the battery, the scroll wheel, and the PCB board.
    • Then use Solder pen to desolder the broken switch off the board.
    • Then, take the broken switch off the board. Once that is finished, get the new switch and put it up against the solder holes. Melt the solder and Insert the switch in the 3 holes.
    • Now just reassemble.
    • Enjoy you fixed mouse!
结论
Enjoy!
Max Murphy
于01/07/19注册
145 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 46
总计 928
