跳转到主内容
加入维修社区 - 创建账户
Logitech MBJ58 Mouse Support Spring Replacement
你所需要的
  1. Logitech MBJ58 Mouse Support Spring Replacement, Top cover: 步骤 1 中的图像 1,1
    • Hold the mouse so that the bottom is facing up.
    • Remove the single Phillips #1 screw from the bottom half of the mouse.
    添加评论
  2. Logitech MBJ58 Mouse Support Spring Replacement: 步骤 2 中的图像 1,2 Logitech MBJ58 Mouse Support Spring Replacement: 步骤 2 中的图像 2,2
    • Place the mouse so that the bottom is resting against a hard surface.
    • Lift the top cover of the mouse gently, and remove it.
    添加评论
  3. Logitech MBJ58 Mouse Support Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: 步骤 3 中的图像 1,3 Logitech MBJ58 Mouse Support Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: 步骤 3 中的图像 2,3 Logitech MBJ58 Mouse Support Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: 步骤 3 中的图像 3,3
    • Locate the scroll wheel on the mouse.
    • Grab the scroll wheel with your thumb and index finger.
    • Gently lift up, to remove the scroll wheel from the mouse.
    添加评论
  4. Logitech MBJ58 Mouse Support Spring Replacement, Support Spring: 步骤 4 中的图像 1,2 Logitech MBJ58 Mouse Support Spring Replacement, Support Spring: 步骤 4 中的图像 2,2
    • Locate the spring on the scroll wheel, and carefully remove the spring.
    添加评论
  5. Logitech MBJ58 Mouse Support Spring Replacement, Attaching the New Spring: 步骤 5 中的图像 1,2 Logitech MBJ58 Mouse Support Spring Replacement, Attaching the New Spring: 步骤 5 中的图像 2,2
    • Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
    添加评论
结论
取消:我没有完成这个指南。
6等其他人完成本指南。
团队
Cal Poly, Team 5-14, Forte Winter 2013 Cal Poly, Team 5-14, Forte Winter 2013 的会员
CPSU-FORTE-W13S5G14
5 名成员
创作了23篇指南
1指南评论
The thing with the spring - still in 2024 helpful!
Thanks a lot! :-)
Michaela Meyer - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 19
过去 30 天: 82
总计 5,220
