跳转到主内容
加入维修社区 - 创建账户
Logitech MBJ58 Mouse Resistance Spring Replacement
你所需要的
  1. Logitech MBJ58 Mouse Resistance Spring Replacement, Top cover: 步骤 1 中的图像 1,1
    • Hold the mouse so that the bottom is facing up.
    • Remove the single Phillips #1 screw from the bottom half of the mouse.
    添加评论
  2. Logitech MBJ58 Mouse Resistance Spring Replacement: 步骤 2 中的图像 1,2 Logitech MBJ58 Mouse Resistance Spring Replacement: 步骤 2 中的图像 2,2
    • Place the mouse so that the bottom is resting against a hard surface.
    • Lift the top cover of the mouse gently, and remove it.
    添加评论
  3. Logitech MBJ58 Mouse Resistance Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: 步骤 3 中的图像 1,3 Logitech MBJ58 Mouse Resistance Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: 步骤 3 中的图像 2,3 Logitech MBJ58 Mouse Resistance Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: 步骤 3 中的图像 3,3
    • Locate the scroll wheel on the mouse.
    • Grab the scroll wheel with your thumb and index finger.
    • Gently lift up, to remove the scroll wheel from the mouse.
    添加评论
  4. Logitech MBJ58 Mouse Resistance Spring Replacement, Support Spring: 步骤 4 中的图像 1,2 Logitech MBJ58 Mouse Resistance Spring Replacement, Support Spring: 步骤 4 中的图像 2,2
    • Locate the spring on the scroll wheel, and carefully remove the spring.
    添加评论
  5. Logitech MBJ58 Mouse Resistance Spring Replacement, Attaching the New Spring: 步骤 5 中的图像 1,2 Logitech MBJ58 Mouse Resistance Spring Replacement, Attaching the New Spring: 步骤 5 中的图像 2,2
    • Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
    添加评论
  6. Logitech MBJ58 Mouse Resistance Spring Replacement, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: 步骤 6 中的图像 1,3 Logitech MBJ58 Mouse Resistance Spring Replacement, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: 步骤 6 中的图像 2,3 Logitech MBJ58 Mouse Resistance Spring Replacement, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: 步骤 6 中的图像 3,3
    • Use the images to locate where the resistance spring is.
    • This spring will easily fall off.
    • Grab the scroll wheel and its mount and gently pull them apart.
    添加评论
  7. Logitech MBJ58 Mouse Resistance Spring Replacement, Resistance Spring: 步骤 7 中的图像 1,2 Logitech MBJ58 Mouse Resistance Spring Replacement, Resistance Spring: 步骤 7 中的图像 2,2
    • Grasp the top of the resistance spring and pull it towards yourself, letting the hook slide out of its hole.
    询问修复机器人
    添加评论
  8. Logitech MBJ58 Mouse Resistance Spring Replacement: 步骤 8 中的图像 1,1
    • Insert the hooked section of the replacement spring into the corresponding hole on the mount.
    添加评论
结论
取消:我没有完成这个指南。
15等其他人完成本指南。
团队
Cal Poly, Team 5-14, Forte Winter 2013 Cal Poly, Team 5-14, Forte Winter 2013 的会员
CPSU-FORTE-W13S5G14
5 名成员
创作了23篇指南
10指南评论
This mouse was also available from Dell as an OEM device under the model name "M-UVDEL1". Hopefully the Google juice will help folks repair their devices. I know I would have spent far more time than I did if it weren't for the photos on how to put the spring back. Thanks Maximilian!
Bastien Nocera - 回复 分享
The spring installation details were lifesavers. Thank you!
LB
byard - 回复 分享
thank you! could not have done it without your help.
taiyo_yuden_dvd - 回复 分享
Brilliant. Thanks. Easy once you know how. The springs were the hard part.
Charles Thomson - 回复 分享
Thank you so much!! You made it very easy and quick!
vulcanmeister - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 22
过去 30 天: 125
总计 13,500
