跳转到主内容
加入维修社区 - 创建账户
Logitech MBJ58 Mouse Buttons Replacement
你所需要的
  1. Logitech MBJ58 Mouse Buttons Replacement, Top cover: 步骤 1 中的图像 1,1
    • Hold the mouse so that the bottom is facing up.
    • Remove the single Phillips #1 screw from the bottom half of the mouse.
    添加评论
  2. Logitech MBJ58 Mouse Buttons Replacement: 步骤 2 中的图像 1,2 Logitech MBJ58 Mouse Buttons Replacement: 步骤 2 中的图像 2,2
    • Place the mouse so that the bottom is resting against a hard surface.
    • Lift the top cover of the mouse gently, and remove it.
    添加评论
  3. Logitech MBJ58 Mouse Buttons Replacement, Buttons: 步骤 3 中的图像 1,2 Logitech MBJ58 Mouse Buttons Replacement, Buttons: 步骤 3 中的图像 2,2
    • Locate the two tabs that are protruding from the button assembly.
    • Be careful not to break either of the two tabs by squeezing too hard.
    • Pinch the tabs together to free the buttons.
    询问修复机器人
    添加评论
  4. Logitech MBJ58 Mouse Buttons Replacement: 步骤 4 中的图像 1,2 Logitech MBJ58 Mouse Buttons Replacement: 步骤 4 中的图像 2,2
    • Remove the button assembly from the top cover by flipping the top cover upside down and pulling the button assembly downward and away from the top cover.
    • Slide the button assembly out from the top cover through the opening.
    • When fully disassembled, the top cover and the button assembly should look like this.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
Cal Poly, Team 5-14, Forte Winter 2013 Cal Poly, Team 5-14, Forte Winter 2013 的会员
CPSU-FORTE-W13S5G14
5 名成员
创作了23篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 31
总计 3,436
