跳转到主内容
本篇指南是分解流程而非维修指南。 如果您要维修您的Logitech M650 L,应参考我们的维修指南
  1. Logitech M650 L  Mouse Teardown, The Start: 步骤 1 中的图像 1,1
    • Remove the back plate and the battery with the receiver
  2. Logitech M650 L  Mouse Teardown, The Start: 步骤 2 中的图像 1,3 Logitech M650 L  Mouse Teardown, The Start: 步骤 2 中的图像 2,3 Logitech M650 L  Mouse Teardown, The Start: 步骤 2 中的图像 3,3
    • Use your Phillips 00 screwdriver to unscrew the 2 screws as shown in the image. Be careful when removing the bottom part of the mouse because there is a cable you have to disconnect.
  3. Logitech M650 L  Mouse Teardown, Bottom Part: 步骤 3 中的图像 1,3 Logitech M650 L  Mouse Teardown, Bottom Part: 步骤 3 中的图像 2,3 Logitech M650 L  Mouse Teardown, Bottom Part: 步骤 3 中的图像 3,3
    • Using your Phillips 000 screwdriver or bit, unscrew the 2 screws holding down the scroll wheel.
  4. Logitech M650 L  Mouse Teardown, The Bottom: 步骤 4 中的图像 1,3 Logitech M650 L  Mouse Teardown, The Bottom: 步骤 4 中的图像 2,3 Logitech M650 L  Mouse Teardown, The Bottom: 步骤 4 中的图像 3,3
    • Now, using the same bit, unscrew the 2 screws holding the board down.
  5. Logitech M650 L  Mouse Teardown, The Top: 步骤 5 中的图像 1,1
    • Now, on the top side of the mouse, you're going unscrew the screw at the back
  6. Logitech M650 L  Mouse Teardown, The Top: 步骤 6 中的图像 1,1
    • Next, you're going to use your Phillips 00 screwdriver or bit and unscrew the screw on the tiny board.
  7. Logitech M650 L  Mouse Teardown, The Top: 步骤 7 中的图像 1,2 Logitech M650 L  Mouse Teardown, The Top: 步骤 7 中的图像 2,2
    • Now using a spudger or your hand, your going to pull and pry at the back of the mouse to remove the upper layer
  8. Logitech M650 L  Mouse Teardown, The Tiny Board: 步骤 8 中的图像 1,3 Logitech M650 L  Mouse Teardown, The Tiny Board: 步骤 8 中的图像 2,3 Logitech M650 L  Mouse Teardown, The Tiny Board: 步骤 8 中的图像 3,3
    • Finally you can remove the tiny board. First remove the cable, then pull up on the cable to remove the board
  9. Logitech M650 L  Mouse Teardown, You're Done!!!: 步骤 9 中的图像 1,1
    • Hooray! You're done. Now put it back together.
Benjamin
于01/04/25注册
169 声望
撰写一个指南
1指南评论
정말 잘 보고 갑니다. 덕분에 분해 잘했습니다😁
NightFox - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 98
总计 2,124
