跳转到主内容
Logitech M570 Wireless Trackball Switches Replacement
你所需要的
  1. Logitech M570 Wireless Trackball Switches Replacement, Preparation: 步骤 1 中的图像 1,3 Logitech M570 Wireless Trackball Switches Replacement, Preparation: 步骤 1 中的图像 2,3 Logitech M570 Wireless Trackball Switches Replacement, Preparation: 步骤 1 中的图像 3,3
    • Remove tracking ball
    • Turn power switch to the off position
    • Open battery door
    • Remove AA battery
  2. Logitech M570 Wireless Trackball Switches Replacement, Taking mouse body apart: 步骤 2 中的图像 1,1
    • Remove 3 pads as shown in the picture
    • Unscrew the 5 bolts using Phillips #1 screwdriver
    • The last screw is hidden under the battery label. You will have to poke a hole to get to it.
  3. Logitech M570 Wireless Trackball Switches Replacement, Detaching PCB: 步骤 3 中的图像 1,3 Logitech M570 Wireless Trackball Switches Replacement, Detaching PCB: 步骤 3 中的图像 2,3 Logitech M570 Wireless Trackball Switches Replacement, Detaching PCB: 步骤 3 中的图像 3,3
    • Lift the latch up and pull flex circuit out of connector. Detach tracking ball sensor.
    • Unscrew first screw and detach little PCB
    • Take the other 3 screws out. The last screw is hidden behind a capacitor in the picture
  4. Logitech M570 Wireless Trackball Switches Replacement, Removing PCB: 步骤 4 中的图像 1,2 Logitech M570 Wireless Trackball Switches Replacement, Removing PCB: 步骤 4 中的图像 2,2
    • Carefully remove PCB. Take care not to bend battery connector
    • Remove power switch. Otherwise it might fall out and you will never see it again...
  5. Logitech M570 Wireless Trackball Switches Replacement, Replacing switches: 步骤 5 中的图像 1,3 Logitech M570 Wireless Trackball Switches Replacement, Replacing switches: 步骤 5 中的图像 2,3 Logitech M570 Wireless Trackball Switches Replacement, Replacing switches: 步骤 5 中的图像 3,3
    • As you may see one of the switches is completely busted. It has to be replaced!
    • There are few replacements out there. I've used this one. But you might want to use original one. Or the rival one.
    • It really does not matter much. The difference is operating force. The original one comes with 75 gf which gives lighter clicking action. But I went with 150 gf for the replacement since those should last longer...
    • Take old switches out. Might be a little tricky! You might want to use multiple soldering irons to heat all 3 pins at once. Or heat gun. The choice is yours. Just be careful not to burn yourself! FYI, this is probably not the best project for the first soldering experience!
    • Solder new switches on.
结论
To reassemble your device, follow these instructions in the reverse order.
40等其他人完成本指南。
Kirill
于04/11/17注册
1,640 声望
创作了2篇指南
21指南评论
Instructions are very clear and accurate. The most difficult part of this repair is de-soldering the switch, additional information is needed for this step.
Hugo Castro - 回复
Yeah, you either have to use 2 irons to apply heat to 3 pins at the same time. Or take apart body of the switch and cut one of the pins from the body. That way you can use one iron to apply heat to 2 pins at the same time to get it detached from PCB
Kirill - 回复
Folks, use a solder sucker and a solder wick. There should be many articles out there on using solder (extractor) sucker and wick. But basically you melt solder , solder sucker sucks up the most of it (Put the tip right over the end of the metal leg RIGHT after melting) All has to happenen very quickly.
Then the solder wick, you rub over the metal pins using the solder iron to push it along the PCB around the pins and the switch will just drop out.
No offence to any one but the article author did say not advised for your first solder experience, and using solder wick etc would be a veteran solder master trick.
https://www.google.com/url?sa=t&rct=j&q=...
john sloan - 回复
Fine multi-strand wire from an old phone extension cable is good as a wick to remove solder - use a tiny amount of flux to help.
Christopher -
An aside to replacing the switches: if you’re having problems with click bounce and a regular contact cleaner isn’t working you could try an oil for electric model train motor commutators: Peco Electrics Power-Lube PL-64 - I picked up a little in a model shop but you can buy it online in the UK for around £6 to £7 for a couple of mL - the key bounce problems have largely disappeared after one or two applications both for my M570s and for an older cordless trackman wheel that I had given up on. If you have one of these it is worth noting that they will run perfectly well on NiMH rechargeable cells whereas the M570 will not. The latter may win out on simple battery life but on the environmental side: using a rechargeable cell should be better in the longer term especially as the grid gets a higher proportion of renewables.
Christopher - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 32
过去 30 天: 234
总计 24,206
