跳转到主内容
加入维修社区 - 创建账户
Logitech M515 (Couch) Mouse
你所需要的
  1. Logitech M515 (Couch) Mouse, Removing the outer shell: 步骤 1 中的图像 1,1
    • Remove the battery hatch and batteries.
  2. Logitech M515 (Couch) Mouse: 步骤 2 中的图像 1,1
    • Remove the single Phillips screw located between the battery sockets.
  3. Logitech M515 (Couch) Mouse: 步骤 3 中的图像 1,1
    • Lift the rear of the top case of the mouse and slide forward. It should be fairly easy to release.
结论
5等其他人完成本指南。
Anna Sweetnam
于04/08/10注册
262 声望
撰写一个指南
4指南评论
I got to step 3. where is step 4?
hawaii50 - 回复
What are you trying to do? All of the innards are available once step 3 is complete.
Anna Sweetnam - 回复
Hi, just to say that its a utility named ProxyTool from Logitech that can be used to adjust the behavior of hand detection feature. here you go the file: ftp://ftp.logitech.com/pub/techsupport/m... or https://www.dropbox.com/s/z1rq7s6wzt4ohu...
You can literaly disable the Couch Mouse M515 hand proximity sensor
Luis Frederico - 回复
M545 works similarly btw
Adri Idzwan Mansor - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 28
总计 5,382
