跳转到主内容
加入维修社区 - 创建账户
Logitech M500 Mouse Switch Replacement
你所需要的
  1. Logitech M500 Mouse Switch Replacement, Remove rubber feet: 步骤 1 中的图像 1,2 Logitech M500 Mouse Switch Replacement, Remove rubber feet: 步骤 1 中的图像 2,2
    • The screws are hidden under the four rubber feet on the underside of the mouse.
    • Carefully peel away each foot and its layer of adhesive, putting them to the side to replace later.
  2. Logitech M500 Mouse Switch Replacement, Remove the screws and top casing: 步骤 2 中的图像 1,2 Logitech M500 Mouse Switch Replacement, Remove the screws and top casing: 步骤 2 中的图像 2,2
    • Unscrew the four Phillips #0 screws hidden by the feet.
    • The top casing should now come loose with just a shake.
  3. Logitech M500 Mouse Switch Replacement, Free the USB cable: 步骤 3 中的图像 1,2 Logitech M500 Mouse Switch Replacement, Free the USB cable: 步骤 3 中的图像 2,2
    • Gently pull the USB cable out of its channel.
  4. Logitech M500 Mouse Switch Replacement, Unplug the USB cable: 步骤 4 中的图像 1,2 Logitech M500 Mouse Switch Replacement, Unplug the USB cable: 步骤 4 中的图像 2,2
    • Grip the white plastic plug and remove it from its socket.
    • This may take some force. Try to pull straight upwards as much as possible, but it may help to wiggle the plug back and forth.
  5. Logitech M500 Mouse Switch Replacement, Remove the scroll wheel: 步骤 5 中的图像 1,3 Logitech M500 Mouse Switch Replacement, Remove the scroll wheel: 步骤 5 中的图像 2,3 Logitech M500 Mouse Switch Replacement, Remove the scroll wheel: 步骤 5 中的图像 3,3
    • The scroll wheel is held in place by a plastic pin. Pull it sideways to remove it.
    • Grip the scroll wheel assembly by the transparent part and lift it out.
    • Two small springs at the front of the mouse are held in place by this assembly. Be careful not to lose them when removing it.
  6. Logitech M500 Mouse Switch Replacement, Remove scroll wheel mount: 步骤 6 中的图像 1,3 Logitech M500 Mouse Switch Replacement, Remove scroll wheel mount: 步骤 6 中的图像 2,3 Logitech M500 Mouse Switch Replacement, Remove scroll wheel mount: 步骤 6 中的图像 3,3
    • Remove the two screws that secure the plastic wheel mount in the centre of the circuit board.
    • You don't have to unscrew them all the way, just enough to free the wheel mount.
    • Lift the wheel mount off the circuit board.
  7. Logitech M500 Mouse Switch Replacement, Remove metal piece: 步骤 7 中的图像 1,2 Logitech M500 Mouse Switch Replacement, Remove metal piece: 步骤 7 中的图像 2,2
    • Undo the two screws holding down the metal piece at the front of the mouse.
    • Remove the metal piece.
  8. Logitech M500 Mouse Switch Replacement, Put the springs somewhere safe: 步骤 8 中的图像 1,1
    • Two springs sit in holes in the circuit board at the front of the mouse. Put them somewhere safe.
  9. Logitech M500 Mouse Switch Replacement, Remove the circuit board: 步骤 9 中的图像 1,3 Logitech M500 Mouse Switch Replacement, Remove the circuit board: 步骤 9 中的图像 2,3 Logitech M500 Mouse Switch Replacement, Remove the circuit board: 步骤 9 中的图像 3,3
    • Remove the last screw holding down the circuit board (next to the hole left by the scroll wheel).
    • Remove the circuit board by lifting it up at the front.
    • There will be some resistance to lifting up the board, until the plastic that the wheel mount was screwed into snaps out of its holes in the circuit board.
  10. Logitech M500 Mouse Switch Replacement, Desolder the old switch: 步骤 10 中的图像 1,2 Logitech M500 Mouse Switch Replacement, Desolder the old switch: 步骤 10 中的图像 2,2
    • Double-check that you're removing the switch that you intend to!
    • Remove the solder from the three pins of the old switch.
    • If you have one, a desoldering gun is the easiest tool to use. Otherwise, you could use a handheld desoldering pump or some desoldering braid along with a soldering iron.
    • Pull the old switch out of its holes. You may need to loosen any remaining drops of solder with a soldering iron while doing this.
  11. Logitech M500 Mouse Switch Replacement, Solder the replacement switch: 步骤 11 中的图像 1,2 Logitech M500 Mouse Switch Replacement, Solder the replacement switch: 步骤 11 中的图像 2,2
    • Insert the new switch into the holes, being careful to put it in the right way around. The white button on the top of the switch should be closest to the front end of the circuit board.
    • Solder the new switch into place.
    • Before reassembling the mouse, you may wish to reconnect the USB cable, plug it into a computer, and check that the new switch works.
结论
另外一个人完成了本指南。
Harry Cutts
于06/14/20注册
1,448 声望
创作了8篇指南
2指南评论
Thank you very much for your great repair guide.
It helped me to put my Logitech M500 Mouse back together, after I had fixed it on my own beforehand.
DEsigner - 回复
Worked like a charm, getting the springs back in position was a pain in the *** though. You might want to make sure that your tools are not magnetized.
Markus29 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 85
总计 2,062
