跳转到主内容
加入维修社区 - 创建账户
Logitech M325 Scroll Wheel Replacement
你所需要的
  1. Logitech M325 Scroll Wheel Replacement, Scroll Wheel: 步骤 1 中的图像 1,1
    • Caution: Before you begin, ensure that the mouse is powered off (red color displayed on the switch). The switch can be found at the bottom of the mouse.
    • Remove the battery cover from the bottom of the mouse by sliding downwards.
  2. Logitech M325 Scroll Wheel Replacement: 步骤 2 中的图像 1,2 Logitech M325 Scroll Wheel Replacement: 步骤 2 中的图像 2,2
    • Lift out the AA battery.
    • Remove the USB adapter.
  3. Logitech M325 Scroll Wheel Replacement: 步骤 3 中的图像 1,1
    • Peel off the sticker in the battery compartment to reveal the screw underneath.
  4. Logitech M325 Scroll Wheel Replacement: 步骤 4 中的图像 1,2 Logitech M325 Scroll Wheel Replacement: 步骤 4 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the 5 mm screw in the battery compartment.
  5. Logitech M325 Scroll Wheel Replacement: 步骤 5 中的图像 1,2 Logitech M325 Scroll Wheel Replacement: 步骤 5 中的图像 2,2
    • Slide the lower case downwards and separate the top case from the main mouse body by lifting it off.
  6. Logitech M325 Scroll Wheel Replacement: 步骤 6 中的图像 1,2 Logitech M325 Scroll Wheel Replacement: 步骤 6 中的图像 2,2
    • Use a pry tool to unclip the scroll wheel from the PCB by pushing the clip out of the holder.
    • Remove the scroll wheel by lifting it up.
  7. Logitech M325 Scroll Wheel Replacement: 步骤 7 中的图像 1,2 Logitech M325 Scroll Wheel Replacement: 步骤 7 中的图像 2,2
    • Align the replacement in the same position as the old scroll wheel.
    • Push down and clip in the scroll wheel.
  8. Logitech M325 Scroll Wheel Replacement: 步骤 8 中的图像 1,3 Logitech M325 Scroll Wheel Replacement: 步骤 8 中的图像 2,3 Logitech M325 Scroll Wheel Replacement: 步骤 8 中的图像 3,3
    • Align the top housing clips with the mouse body clip openings.
    • Slide top housing back onto mouse by pushing it in.
结论
To reassemble your device, follow steps 1-4 in reverse order.
另外一个人完成了本指南。
mykayat_YU
于01/09/25注册
157 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 37
总计 398
