跳转到主内容
加入维修社区 - 创建账户
Logitech M317C Mouse Switch Replacement
你所需要的
  1. Logitech M317C Mouse Switch Replacement, Mouse Switch: 步骤 1 中的图像 1,1
    • The mouse before starting
  2. Logitech M317C Mouse Switch Replacement: 步骤 2 中的图像 1,1
    • Flip over the mouse, removing the battery cover, USB receiver, and single Phillips 0 screw.
  3. Logitech M317C Mouse Switch Replacement: 步骤 3 中的图像 1,1
    • Lift off the top cover of the mouse. No cables hold it in place.
  4. Logitech M317C Mouse Switch Replacement: 步骤 4 中的图像 1,1
    • The board is held in place with several plastic clips. Use a spudger to gently push the clip next to the battery compartment. The board should raise slightly.
  5. Logitech M317C Mouse Switch Replacement: 步骤 5 中的图像 1,1
    • Lift the board out of the mouse, towards the back of the mouse (note the clips in front).
    • Keep track of the power switch, as it may fall out when you remove the board. If it does, note the position of the on/off switch on the board and replace the switch.
  6. Logitech M317C Mouse Switch Replacement: 步骤 6 中的图像 1,1
    • Desolder the 3 points of each switch as needed (upper and lower left solder points in photo).
  7. Logitech M317C Mouse Switch Replacement: 步骤 7 中的图像 1,1
    • The original, non-clicking switch indicated.
  8. Logitech M317C Mouse Switch Replacement: 步骤 8 中的图像 1,1
    • Solder the new switch into place, and reinsert the board.
    • Ensure all three clips hold the board in place, that the power switch is installed correctly, and the battery holder is inserted in the cavity at each end of the compartment.
    • Reinstall the cover and test!
结论
Jon
于07/16/14注册
1,002 声望
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 24
总计 145
