跳转到主内容
加入维修社区 - 创建账户
Logitech M310 Mouse Wheel Spring Repair
你所需要的
  1. Logitech M310 Mouse Wheel Spring Repair, Logitech M310 Mouse Wheel Spring Repair: 步骤 1 中的图像 1,2 Logitech M310 Mouse Wheel Spring Repair, Logitech M310 Mouse Wheel Spring Repair: 步骤 1 中的图像 2,2
    • Check if the scroll wheel is spinning freely without resistance.
    • A correctly aligned spring will cause the wheel to ratchet in small increments
  2. Logitech M310 Mouse Wheel Spring Repair: 步骤 2 中的图像 1,3 Logitech M310 Mouse Wheel Spring Repair: 步骤 2 中的图像 2,3 Logitech M310 Mouse Wheel Spring Repair: 步骤 2 中的图像 3,3
    • Use your thumb to press the indentation on the bottom battery cover.
    • Slide down the battery cover and fully remove the battery cover.
    • Remove the battery.
  3. Logitech M310 Mouse Wheel Spring Repair: 步骤 3 中的图像 1,3 Logitech M310 Mouse Wheel Spring Repair: 步骤 3 中的图像 2,3 Logitech M310 Mouse Wheel Spring Repair: 步骤 3 中的图像 3,3
    • Remove two Phillips #1 screws.
  4. Logitech M310 Mouse Wheel Spring Repair: 步骤 4 中的图像 1,3 Logitech M310 Mouse Wheel Spring Repair: 步骤 4 中的图像 2,3 Logitech M310 Mouse Wheel Spring Repair: 步骤 4 中的图像 3,3
    • Remove the bottom board plate from the mouse body by pulling it down and away.
    • Ensure not to apply the force perpendicular to the mouse body. The board will only remove in a downward direction.
  5. Logitech M310 Mouse Wheel Spring Repair: 步骤 5 中的图像 1,3 Logitech M310 Mouse Wheel Spring Repair: 步骤 5 中的图像 2,3 Logitech M310 Mouse Wheel Spring Repair: 步骤 5 中的图像 3,3
    • Use the 2mm flat head to lift up the spring leg.
    • Use the screwdriver as a lever to pry the spring leg back into the scroll wheel
    • You may need to use your thumb to pull the scroll wheel to the left a few millimeters, creating enough of a gap on the right side for the spring leg to fit into the mouse wheel cavity.
    • The spring leg should no longer be visible once aligned inside the mouse wheel cavity.
  6. Logitech M310 Mouse Wheel Spring Repair: 步骤 6 中的图像 1,3 Logitech M310 Mouse Wheel Spring Repair: 步骤 6 中的图像 2,3 Logitech M310 Mouse Wheel Spring Repair: 步骤 6 中的图像 3,3
    • Before reassembling the mouse, confirm if the scroll wheel is fixed appropriately.
    • Gently place the mouse down on the table and scroll the wheel. There should now be a noticeable difference in resistance, and it should no longer freely spin.
    • If the scroll wheel is still not fixed, you may need to readjust the spring into the cavity again (see Step 5).
结论
12等其他人完成本指南。
Karmit Dandona
于02/18/20注册
437 声望
撰写一个指南
团队
UC Davis, Team S2-G2, Andersen Winter 2020 UC Davis, Team S2-G2, Andersen Winter 2020 的会员
UCD-ANDERSEN-W20S2G2
4 名成员
创作了2篇指南
9指南评论
Great tutorial. I thought I needed to buy another one. With this I managed to fix it under 2 minutes. Thanks! :)
StopShop GSM - 回复 分享
Excellent instructions, I searched the web for days looking for the solution. I could not determine if it was software or hardware, the mouse wheel has always spun free, no clicking. After following your instructions, it clicks when I scroll and the spontaneous jumping is gone. Thanks a million!
Bob Weenig - 回复 分享
Fantastic instructions! I was struggling to find out how the spring should be placed for the proper ratcheting behavior. This walk-through got me there in less than a minute. Thank you very much!
Sean Smith - 回复 分享
Is there any way to replace the spring if lost?
Connor - 回复 分享
Thanks so much for the great tutorial. The pictures really helped.
Maureen - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 41
过去 30 天: 224
总计 11,293
