跳转到主内容
Logitech M220 Silent Mouse Left Mouse Button Not Working Properly Fix
你所需要的
视频概述
  1. Logitech M220 Silent Mouse Left Mouse Button Not Working Properly Fix, How to fix a Logitech M220 silentmouse left button not working: 步骤 1 中的图像 1,1
    • Remove battery cap and 1.5V AA battery on the underside of the mouse.
    • The black spot is a Phillips cheese head screw. Remove the screw (anti-clockwise).
    • Note: Do not lose the small screw.
  2. Logitech M220 Silent Mouse Left Mouse Button Not Working Properly Fix: 步骤 2 中的图像 1,1
    • Now turn over the mouse, and gently move the top-half of the mouse towards you, with a little wiggle.
    • The result should be that the cover of the mouse gives room, and you can take off the cover of the mouse (with the wheel).
    • Here you can see the lips on the wheel side that should slide off the protrusions on the bottom side.
  3. Logitech M220 Silent Mouse Left Mouse Button Not Working Properly Fix: 步骤 3 中的图像 1,1
    • The PCB inside the mouse is held in place with 3 clips. The easiest way to hold these back is with a set of picks. I put a pick on the bottom and the right side and was able to wiggle the PCB out of its position, along with the two battery springs.
    • Be careful with the battery springs which are attached to the PCB. Make sure they do not get bent or are left in the bottom plastic housing.
    • With the mouse disassembled, you can clean the plastic mouse housing with 70% isopropyl alcohol or an alcohol wet wipe.
    • Note: Do not lose the small plastic on-off slide button
  4. Logitech M220 Silent Mouse Left Mouse Button Not Working Properly Fix: 步骤 4 中的图像 1,2 Logitech M220 Silent Mouse Left Mouse Button Not Working Properly Fix: 步骤 4 中的图像 2,2
    • Now that the PCB is loose from the bottom plastic of the mouse, you can check the contacts of the microswitches.
    • I noticed discoloring of the solder, and the microswitch seemed to wiggle a bit.
  5. Logitech M220 Silent Mouse Left Mouse Button Not Working Properly Fix: 步骤 5 中的图像 1,1
    • Resolder the connections.
  6. Logitech M220 Silent Mouse Left Mouse Button Not Working Properly Fix: 步骤 6 中的图像 1,1
    • When pushing the PCB back into the bottom part of the mouse, make sure the plastic on/off slide button of the mouse is aligned with the tiny handle of the slide switch on PCB.
  7. Logitech M220 Silent Mouse Left Mouse Button Not Working Properly Fix: 步骤 7 中的图像 1,1
    • Now with the PCB reinserted in the bottom of the mouse, reinsert the battery before trying to push the cover on top, to make sure the mouse is in working order. You can press the switches and move the mouse to see if everything is OK.
结论
10等其他人完成本指南。
johan
于01/21/11注册
329 声望
撰写一个指南
8指南评论
I'm looking for replacement switches for pebble mice. I have 2 M355s with failing switches. Lube did not help and made 1 of the switches stop returning all the way from the down position. So I'd just like to replace the switches because they are otherwise great mice.
Ed Pike - 回复
Try this: 6mm x 6mm x 4.3mm (height) 2-pin microswitch. Check Reviews section for photos.
https://a.aliexpress.com/_mtHdF6K
Butterflybug -
I have had 3 M330 silent mouse with failing left switches. However, I was able to recover them by disassembly, cleaning with alcohol and adding a tiny bit of oil /wd40. This video demonstrates. It fixed 2 of the mice and improved the 3rd.
https://www.youtube.com/watch?v=-w-W6MAn...
garbage911garbage - 回复
In my case the left click didn't work any more so I removed the left click switch and moved the richt click switch in its place to make it mostly usable until the replacement switch will arrive. In my case a right click can be had with a left click when also pressing a modifier key (ctrl in my case on MacOS). Thank you johan for the tutorial and Butterflybug for the link to the appropriate switches.
Fabian - 回复
I used these: "Original Kailh Silent Mouse Micro Switch Red Yellow Dot Square Mute Micro Switches For M330 M220 M590 6*6*7.3mm" https://www.aliexpress.com/item/10050054...
And the fix worked. Thanks again for the instructions and help with finding the right replacement parts.
Fabian -
添加评论
浏览统计数据:
过去 24 小时: 15
过去 7 天: 111
过去 30 天: 466
总计 26,302
