跳转到主内容
加入维修社区 - 创建账户
Logitech M215 Top Cover Replacement
你所需要的
  1. Logitech M215 Top Cover Replacement, Remove the battery cover: 步骤 1 中的图像 1,3 Logitech M215 Top Cover Replacement, Remove the battery cover: 步骤 1 中的图像 2,3 Logitech M215 Top Cover Replacement, Remove the battery cover: 步骤 1 中的图像 3,3
    • The battery compartment cover is located on the top of the mouse. The seam running horizontally across the mouse is the top of the cover.
    • There is a button to pop off the cover. It is located on the bottom of the mouse. you may need to press hard on this button to pop the cover.
    • If the button does not work, you will need to pry off the cover. You can use your fingernails or a prying tool in order to do this, as seen in the third image.
  2. Logitech M215 Top Cover Replacement, Remove old battery: 步骤 2 中的图像 1,1
    • Remember to insert the new battery in the same orientation as the old one. The positive (plus) end should be facing away from the buttons.
  3. Logitech M215 Top Cover Replacement, Top Cover: 步骤 3 中的图像 1,2 Logitech M215 Top Cover Replacement, Top Cover: 步骤 3 中的图像 2,2
    • The pads on the underside of the mouse hide the screws. Remove these first. You may need to use your fingernails or a prying tool.
    • There will be two 0.5mm phillips head screws. Both will be underneath the bottom two pads.
  4. Logitech M215 Top Cover Replacement: 步骤 4 中的图像 1,1
    • Pry the top cover off. You may need to use a pry tool to help.
结论
Hannah Pate
于01/30/15注册
1,742 声望
创作了7篇指南
团队
USF Tampa, Team 1-1, Watkins Winter 2015 USF Tampa, Team 1-1, Watkins Winter 2015 的会员
USFT-WATKINS-W15S1G1
4 名成员
创作了28篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 34
总计 3,070
