跳转到主内容
加入维修社区 - 创建账户
Logitech M185 Wireless Mouse Scroll Wheel Replacement
你所需要的
    1. Logitech M185 Wireless Mouse Scroll Wheel Replacement, Scroll Wheel: 步骤 1 中的图像 1,3 Logitech M185 Wireless Mouse Scroll Wheel Replacement, Scroll Wheel: 步骤 1 中的图像 2,3 Logitech M185 Wireless Mouse Scroll Wheel Replacement, Scroll Wheel: 步骤 1 中的图像 3,3
      • Turn your mouse over so the bottom is facing up.
      • Slide the battery compartment door off to reveal the battery.
      询问修复机器人
      添加评论
    2. Logitech M185 Wireless Mouse Scroll Wheel Replacement: 步骤 2 中的图像 1,1
      • Remove the battery.
      • Use a Phillips #00 screwdriver to remove the single screw in the battery compartment.
      • The screw may be hard to find at first, but it is directly under the battery.
      询问修复机器人
      添加评论
    3. Logitech M185 Wireless Mouse Scroll Wheel Replacement: 步骤 3 中的图像 1,3 Logitech M185 Wireless Mouse Scroll Wheel Replacement: 步骤 3 中的图像 2,3 Logitech M185 Wireless Mouse Scroll Wheel Replacement: 步骤 3 中的图像 3,3
      • Place one hand on the bottom of the mouse and the other on the top. Gently remove the top of the mouse.
      询问修复机器人
      添加评论
    4. Logitech M185 Wireless Mouse Scroll Wheel Replacement: 步骤 4 中的图像 1,2 Logitech M185 Wireless Mouse Scroll Wheel Replacement: 步骤 4 中的图像 2,2
      • Use a spudger and gently pry the motherboard up, to remove it from the mouse.
      • Any damage done to the board could affect the functionality of the mouse. Show EXTRA care when touching the board. Handle it along the edges only and wear ESD safe gloves if possible.
      询问修复机器人
      添加评论
    5. Logitech M185 Wireless Mouse Scroll Wheel Replacement: 步骤 5 中的图像 1,2 Logitech M185 Wireless Mouse Scroll Wheel Replacement: 步骤 5 中的图像 2,2
      • Carefully remove the scroll wheel from the motherboard.
      询问修复机器人
      添加评论
    6. Logitech M185 Wireless Mouse Scroll Wheel Replacement: 步骤 6 中的图像 1,1
      • Insert the new scroll wheel.
      询问修复机器人
      添加评论
    7. Logitech M185 Wireless Mouse Scroll Wheel Replacement: 步骤 7 中的图像 1,3 Logitech M185 Wireless Mouse Scroll Wheel Replacement: 步骤 7 中的图像 2,3 Logitech M185 Wireless Mouse Scroll Wheel Replacement: 步骤 7 中的图像 3,3
      • Replace the motherboard.
      • Gently but firmly press down on it until it is securely in place.
      • You will hear a click or snap, indicating it is in place.
      询问修复机器人
      添加评论
    8. Logitech M185 Wireless Mouse Scroll Wheel Replacement: 步骤 8 中的图像 1,3 Logitech M185 Wireless Mouse Scroll Wheel Replacement: 步骤 8 中的图像 2,3 Logitech M185 Wireless Mouse Scroll Wheel Replacement: 步骤 8 中的图像 3,3
      • Put the top of the mouse back onto the bottom and press them together so they connect.
      • Make sure the edges of the top and bottom of the mouse align so there is a secure connection.
      • Use a Phillips #00 screwdriver to replace the single screw in the battery compartment.
      • Replace the battery and battery cover.
      询问修复机器人
      添加评论
    9. Logitech M185 Wireless Mouse Scroll Wheel Replacement: 步骤 9 中的图像 1,1
      • Plug your mouse into a computer using the USB connector to ensure the scroll wheel is working.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
CSU Los Angeles, Team 7-7, Grodsky Spring 2024 CSU Los Angeles, Team 7-7, Grodsky Spring 2024 的会员
CSULA-GRODSKY-S24S7G7
3 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 47
过去 30 天: 181
总计 3,699
