跳转到主内容
加入维修社区 - 创建账户
Logitech M185 Wireless Mouse Disassembly
你所需要的
  1. Logitech M185 Wireless Mouse Disassembly, Remove the Battery Cover and Battery: 步骤 1 中的图像 1,2 Logitech M185 Wireless Mouse Disassembly, Remove the Battery Cover and Battery: 步骤 1 中的图像 2,2
    • Remove battery cover by sliding it off.
  2. Logitech M185 Wireless Mouse Disassembly, Unscrew: 步骤 2 中的图像 1,2 Logitech M185 Wireless Mouse Disassembly, Unscrew: 步骤 2 中的图像 2,2
    • Unscrew the Phillips #1 screw in the battery compartment after removing the battery.
  3. Logitech M185 Wireless Mouse Disassembly, Remove the top cover: 步骤 3 中的图像 1,1
    • There is no need to remove its rubber feet since it is held together by only one screw.
    • Wiggle the grey part of the top to remove it by pulling it towards you(away from the scroll wheel).
    • Do not pull the grey cover towards the top and do not pull the part near the keys.
    • Reasoning by Jacob Hickey "because in the internal top part of the mouse where the buttons/scroll wheel is, there’s hinges-like “tooth” that’ll snap if you do pull on it. It’s like opening a jewelry box that has a hinge on one end of the box… if that makes sense…"
    • The image is what your mouse should look like in the end.
  4. Logitech M185 Wireless Mouse Disassembly, Remove Circuit Board: 步骤 4 中的图像 1,3 Logitech M185 Wireless Mouse Disassembly, Remove Circuit Board: 步骤 4 中的图像 2,3 Logitech M185 Wireless Mouse Disassembly, Remove Circuit Board: 步骤 4 中的图像 3,3
    • Push back small black clips to release the circuit board.
    • Slide up the metal battery connectors to free them from the casing. (Note that these are soldered to the circuit board.)
    • Fully remove the circuit board with the battery connectors and image sensor still attached.
  5. Logitech M185 Wireless Mouse Disassembly, Separate top casing layers: 步骤 5 中的图像 1,3 Logitech M185 Wireless Mouse Disassembly, Separate top casing layers: 步骤 5 中的图像 2,3 Logitech M185 Wireless Mouse Disassembly, Separate top casing layers: 步骤 5 中的图像 3,3
    • Working from back to front (left to right in the first image) unclip the first two pairs of black plastic clips.
    • Slide the black upper casing forwards over the mouse wheel whilst applying pressure the two front clips to release them.
    • Separate the two casing layers fully.
结论
40等其他人完成本指南。
12指南评论
Thank you Karmanyaah Malhotra for takin’ the time to do this for everybody like me :-)
Jacob Hickey - 回复
TElll me now or else
Brayden Karanian - 回复
添加评论
浏览统计数据:
过去 24 小时: 17
过去 7 天: 130
过去 30 天: 623
总计 40,067
