跳转到主内容
加入维修社区 - 创建账户
Logitech M100 USB Cable Replacement
你所需要的
  1. Logitech M100 USB Cable Replacement, USB Cable: 步骤 1 中的图像 1,2 Logitech M100 USB Cable Replacement, USB Cable: 步骤 1 中的图像 2,2
    • Not all variants of this mouse require the mouse feet to be taken off for disassembly, but their removal is detailed anyway.
    • Carefully remove the feet of the mouse with an opening pick.
    • Keep track of the mouse feet, as you'll be reapplying them at the end of the guide.
  2. Logitech M100 USB Cable Replacement: 步骤 2 中的图像 1,2 Logitech M100 USB Cable Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the 10mm screws on the bottom of the mouse.
    • Once all screws are removed, use the plastic opening tool to gently pry the mouse apart. This shouldn't take much force.
  3. Logitech M100 USB Cable Replacement: 步骤 3 中的图像 1,2 Logitech M100 USB Cable Replacement: 步骤 3 中的图像 2,2
    • Once the mouse is opened, locate the USB cable's 5-pin connector, which is plugged directly into the mouse's mainboard.
    • Take note of the position and route that the USB cable takes before removal. The replacement cable must follow the same route when inserted.
    • Using a plastic opening tool, gently remove the 5-pin connector from the mainboard.
  4. Logitech M100 USB Cable Replacement: 步骤 4 中的图像 1,2 Logitech M100 USB Cable Replacement: 步骤 4 中的图像 2,2
    • Take the replacement USB cable and connect it to the mainboard.
  5. Logitech M100 USB Cable Replacement: 步骤 5 中的图像 1,2 Logitech M100 USB Cable Replacement: 步骤 5 中的图像 2,2
    • Ensure that the 5-pin connector is fully seated into its slot on the mainboard. You may want to use a spudger to apply pressure onto it.
    • Using a plastic opening tool, route the cable through the case in the same way that was noted in Step 3.
  6. Logitech M100 USB Cable Replacement: 步骤 6 中的图像 1,1
    • After re-assembling the mouse, don't forget to reattach the mouse feet onto their correct locations on the bottom of the mouse.
结论
To reassemble, follow the steps in reverse order.
4等其他人完成本指南。
Jake Janicke
于10/26/17注册
161 声望
撰写一个指南
团队
1指南评论
Removing the mouse feet is completely unnecessary, as there are no screws underneath the feet.
Andy Joonseo Bae - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 49
总计 6,253
