你所需要的
Pry open the battery cover on the back of the device using either your hand or a spudger.
Use a spudger to remove the first battery.
Slide the 2nd battery out of the slot.
Insert a spudger into the seam between the black side (front) and the white side (back).
Pry the two halves apart, making your way around the keyboard.
Flip the black side (front) over so the keys face downwards.
Remove the red highlighted screws, then remove the palm rest.
Unplug the ribbon cable connecting the two boards and remove the power switch daughter board.
Unplug the ribbon cable connecting the membrane to the main circuit board.
The Logitech K850 keyboard is quite complex, though it is somewhat easy to fix. However, with a ton of fragile components that need to be pried on, repairs can be difficult.
3等其他人完成本指南。
2条评论
How do I fix the incredibly tiny plastic piece where the foot/stand fits into? Are the side wholes enough to get two new feet without having to worry about that plastic part or does it need ot hook into that?
It is difficult for key plucker to remove keys from.mk850 . Is there a easy way to remove keys from it?
