跳转到主内容
Fix Your Stuff
Right to Repair
Parts & Tools
配件
没有特定配件。
  1. Turn the keyboard over so the back is facing up.
    • Turn the keyboard over so the back is facing up.
    • Remove the 4 rubbers hiding 4 screws
    • Unscrew the 8 visible screws
    • Unclip the two plastic side of the keyboard
    • Careful the maximum opening distance range is limited by an internal connection. Open gently.
    • Unplug the connection avoid the separation of the two plastic parts.
    • Unplug the battery connector from the base side
    • You can now separate the two part of the keyboard
    • Repair the soldering of the micro USB connector
    • Plug the battery connector
    • Plug the connection from the upper part of the keyboard
    • Reassemble both keyboard parts
    • Clip them together
    • Screw in the 8 screws
    • Stick the 4 rubbers at their respective positions
结论
2等其他人完成本指南。
mathieubernou
于2015年05月21日注册
173 信誉积分
撰写一个指南
Repair the welding of the micro usb connector . hi will you please tell me how you soldered it ?
Any help in this will be much appreciated
Healthy & Yummy - 回复
The micro usb connector is also not a standard size. Explaining how you soldered it back on would be helpful. Mine came loose when I plugged it in but it tore the pads off.
jeff - 回复
添加评论
浏览统计数据:
过去的24小时: 3
过去的7天: 18
过去的30天: 59
总计 2,385
