跳转到主内容
加入维修社区 - 创建账户
Logitech K480 Back Cover Replacement
你所需要的
  1. Logitech K480 Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Flip the keyboard over.
  2. Logitech K480 Back Cover Replacement: 步骤 2 中的图像 1,3 Logitech K480 Back Cover Replacement: 步骤 2 中的图像 2,3 Logitech K480 Back Cover Replacement: 步骤 2 中的图像 3,3
    • Remove the four rubber feet with a spudger.
  3. Logitech K480 Back Cover Replacement: 步骤 3 中的图像 1,3 Logitech K480 Back Cover Replacement: 步骤 3 中的图像 2,3 Logitech K480 Back Cover Replacement: 步骤 3 中的图像 3,3
    • Slide open battery panel.
    • Remove the batteries.
  4. Logitech K480 Back Cover Replacement: 步骤 4 中的图像 1,2 Logitech K480 Back Cover Replacement: 步骤 4 中的图像 2,2
    • Remove the three 4 mm screws under the rubber feet using a Phillips #0 screwdriver.
  5. Logitech K480 Back Cover Replacement: 步骤 5 中的图像 1,2 Logitech K480 Back Cover Replacement: 步骤 5 中的图像 2,2
    • Remove the two 4 mm screws from beneath the battery cover using a Phillips #0 screwdriver.
  6. Logitech K480 Back Cover Replacement: 步骤 6 中的图像 1,3 Logitech K480 Back Cover Replacement: 步骤 6 中的图像 2,3 Logitech K480 Back Cover Replacement: 步骤 6 中的图像 3,3
    • Starting by the dial, slide the spudger between the front and back panels until it lifts and snaps.
    • Slide a blue pick in to keep the pieces apart while you work on other areas.
    • Continue prying along the edges until you have enough opened that you can pull both pieces apart gently with your hands.
    • The loud snaps are the clips that hold the pieces together. They're not breaking and you do not need to be alarmed.
结论
另外一个人完成了本指南。
Madison
于09/04/24注册
688 声望
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 62
总计 629
