简介
This guide will cover the disassembly and cleaning of the Logitech K400r wireless keyboard. Before you begin, ensure that you have a small Phillips #0 screwdriver, compressed air, paper towels, and cotton swabs. For you safety, ensure that the device is turned off or the batteries are removed before disassembly.
你所需要的
Use a small Phillips head screwdriver to unscrew all visible screws on the back of the keyboard.
After you have cleaned all components of your keyboard, place the key matrix, key switchboard, and circuit grid back inside the keyboard.
Place all screws back into the exterior of the keyboard and screw them in tightly.
Place batteries back in battery compartment and close the battery port.
Keyboard is reassembled!
5等其他人完成本指南。
1指南评论
Thanks for the guide.
Should be noted that on newer/older (?) boards, the battery compartment is different, and doesn't have a screw in the middle. Instead a screw is hidden under the little serial number to the side of the battery compartment. there is however no sticker on the middle of the back hiding two screws.
You can also remove the keys, by depressing the two snap-in hooks from the back-side. I had to do this as the stablizer on my enter key (ISO layout) wasn't properly on.
EDIT: Just realized I have a K400 plus. Well those are the only differences, so this guide pretty much applies to that too! :)
