跳转到主内容
Logitech Harmony Ultimate Motherboard Replacement
你所需要的
  1. Logitech Harmony Ultimate Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the single 6 mm Phillips #0 screw located beneath the sticker near the USB charging port.
  2. Logitech Harmony Ultimate Motherboard Replacement: 步骤 2 中的图像 1,2 Logitech Harmony Ultimate Motherboard Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool to release tabs that hold the front panel and back panel together. There are three tabs on each side of the device that need to separate for the device to open.
    • The use of a plastic opening tool is recommended to avoid damaging the remote. Use stronger tools as a last resort.
    • Be careful on the right side (looking at the back side) not to hit the screen ribbon cable. If that is hit and breaks, the touchscreen will not work properly. (example shown in the image)
  3. Logitech Harmony Ultimate Motherboard Replacement: 步骤 3 中的图像 1,2 Logitech Harmony Ultimate Motherboard Replacement: 步骤 3 中的图像 2,2
    • Disconnect the wires running from the back cover to the motherboard.
  4. Logitech Harmony Ultimate Motherboard Replacement: 步骤 4 中的图像 1,1
    • Remove the four 6mm Phillips #0 screws from the battery case.
  5. Logitech Harmony Ultimate Motherboard Replacement: 步骤 5 中的图像 1,1
    • The battery is still connected to the device via wiring. To free the battery completely, remove the dark plastic piece from the slot with the plastic opening tool. Slowly rotate the dark plastic piece and the battery clockwise until then can be removed from underneath the small circuit board with the USB port.
    • Removing the dark plastic piece from the motherboard takes some patience, as the remote is designed so that the battery will not dislocate under extreme conditions. The small circuit board with the USB port remains connected to the motherboard by six 10 mm pins.
  6. Logitech Harmony Ultimate Motherboard Replacement: 步骤 6 中的图像 1,1
    • Lift the battery and its case out of the remote.
    • The battery should still be connected to the case with adhesive.
  7. Logitech Harmony Ultimate Motherboard Replacement: 步骤 7 中的图像 1,2 Logitech Harmony Ultimate Motherboard Replacement: 步骤 7 中的图像 2,2
    • Use the plastic opening tool to separate the battery from the case.
  8. Logitech Harmony Ultimate Motherboard Replacement, Motherboard: 步骤 8 中的图像 1,2 Logitech Harmony Ultimate Motherboard Replacement, Motherboard: 步骤 8 中的图像 2,2
    • Remove the four 6mm Phillips #0 screws from the motherboard.
  9. Logitech Harmony Ultimate Motherboard Replacement: 步骤 9 中的图像 1,2 Logitech Harmony Ultimate Motherboard Replacement: 步骤 9 中的图像 2,2
    • There is a flap that connects to the motherboard from the plastic casing. Use fingernails to safely release the flap by flipping the small black buckle upwards.
    • The flap and buckle are underneath the clear yellow piece of tape.
    • Be very careful as damaging this flap could permanently damage your controller.
  10. Logitech Harmony Ultimate Motherboard Replacement: 步骤 10 中的图像 1,1
    • The motherboard is now safe to remove by sliding and lifting it backwards out of place.
结论
另外一个人完成了本指南。
Aaron Diaz
于08/31/15注册
716 声望
创作了3篇指南
团队
USF Tampa, Team 8-1, Eyestone Fall 2015 USF Tampa, Team 8-1, Eyestone Fall 2015 的会员
USFT-EYESTONE-F15S8G1
5 名成员
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 31
总计 2,722
