跳转到主内容
Logitech Harmony Ultimate Charging Station Motherboard Replacement
你所需要的
  1. Logitech Harmony Ultimate Charging Station Motherboard Replacement, Charging Station Motherboard: 步骤 1 中的图像 1,3 Logitech Harmony Ultimate Charging Station Motherboard Replacement, Charging Station Motherboard: 步骤 1 中的图像 2,3 Logitech Harmony Ultimate Charging Station Motherboard Replacement, Charging Station Motherboard: 步骤 1 中的图像 3,3
    • Screws are hidden beneath rubber pads.
    • Peel off the rubber pads.
    • Remove four 6mm screws Phillips #0 screws from the bottom of the device.
  2. Logitech Harmony Ultimate Charging Station Motherboard Replacement: 步骤 2 中的图像 1,2 Logitech Harmony Ultimate Charging Station Motherboard Replacement: 步骤 2 中的图像 2,2
    • Use the plastic opening tool to remove top shell from device.
  3. Logitech Harmony Ultimate Charging Station Motherboard Replacement: 步骤 3 中的图像 1,3 Logitech Harmony Ultimate Charging Station Motherboard Replacement: 步骤 3 中的图像 2,3 Logitech Harmony Ultimate Charging Station Motherboard Replacement: 步骤 3 中的图像 3,3
    • Remove the two (4mm) screws using Phillips 1 screwdriver.
  4. Logitech Harmony Ultimate Charging Station Motherboard Replacement: 步骤 4 中的图像 1,3 Logitech Harmony Ultimate Charging Station Motherboard Replacement: 步骤 4 中的图像 2,3 Logitech Harmony Ultimate Charging Station Motherboard Replacement: 步骤 4 中的图像 3,3
    • Use the Phillips #0 screwdriver to remove the last (4mm) screw. The motherboard can now be removed.
结论
Lucas Reynolds
于09/01/15注册
351 声望
创作了2篇指南
团队
USF Tampa, Team 8-1, Eyestone Fall 2015 USF Tampa, Team 8-1, Eyestone Fall 2015 的会员
USFT-EYESTONE-F15S8G1
5 名成员
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 17
总计 3,099
