跳转到主内容
Logitech Harmony Ultimate Battery Replacement
你所需要的
  1. Logitech Harmony Ultimate Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the single 6 mm Phillips #0 screw located beneath the sticker near the USB charging port.
  2. Logitech Harmony Ultimate Battery Replacement: 步骤 2 中的图像 1,2 Logitech Harmony Ultimate Battery Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool to release tabs that hold the front panel and back panel together. There are three tabs on each side of the device that need to separate for the device to open.
    • The use of a plastic opening tool is recommended to avoid damaging the remote. Use stronger tools as a last resort.
    • Be careful on the right side (looking at the back side) not to hit the screen ribbon cable. If that is hit and breaks, the touchscreen will not work properly. (example shown in the image)
  3. Logitech Harmony Ultimate Battery Replacement: 步骤 3 中的图像 1,2 Logitech Harmony Ultimate Battery Replacement: 步骤 3 中的图像 2,2
    • Disconnect the wires running from the back cover to the motherboard.
  4. Logitech Harmony Ultimate Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the four 6mm Phillips #0 screws from the battery case.
  5. Logitech Harmony Ultimate Battery Replacement: 步骤 5 中的图像 1,1
    • The battery is still connected to the device via wiring. To free the battery completely, remove the dark plastic piece from the slot with the plastic opening tool. Slowly rotate the dark plastic piece and the battery clockwise until then can be removed from underneath the small circuit board with the USB port.
    • Removing the dark plastic piece from the motherboard takes some patience, as the remote is designed so that the battery will not dislocate under extreme conditions. The small circuit board with the USB port remains connected to the motherboard by six 10 mm pins.
  6. Logitech Harmony Ultimate Battery Replacement: 步骤 6 中的图像 1,1
    • Lift the battery and its case out of the remote.
    • The battery should still be connected to the case with adhesive.
  7. Logitech Harmony Ultimate Battery Replacement: 步骤 7 中的图像 1,2 Logitech Harmony Ultimate Battery Replacement: 步骤 7 中的图像 2,2
    • Use the plastic opening tool to separate the battery from the case.
结论
34等其他人完成本指南。
Aaron Diaz
于08/31/15注册
716 声望
创作了3篇指南
团队
USF Tampa, Team 8-1, Eyestone Fall 2015 USF Tampa, Team 8-1, Eyestone Fall 2015 的会员
USFT-EYESTONE-F15S8G1
5 名成员
创作了9篇指南
20指南评论
A bit dissapointed with Logitech’s “throw the remote away when the battery dies” instructions on their site. However, this guide was easy and means I have a functioning remote again (only 18 months old!). Many thanks for the guide.
Alec Dunn - 回复
Step 6 (disassembly and re-assembly) Only thing to point out is that the PCB on the bottom of the battery holder twists into the holder (small plastic holding feature). This is important to get proper alignment of the Micro-USB connector). When removing the battery holder make sure the PCB pops out of the snap that is on the opposite side from the screw that holds the Micro-USB connector. This avoids putting too much strain on the leads of that PCB.
Brian - 回复
Wish I read the comments before I did the work - came close to snapping the leads. To anyone trying this, the battery holder is not attached to that small pcb but rather there are small notches that hold the battery case in place. Knowing that will allow you to apply the right pressure in the right places to move it away from the PCB.
vinny -
Rest of the instructions were fairly self explanatory, although I'm grateful for the confirmation to reduce risk
This point is an absolute saver though!
Fixing is Play -
Battery model please
Mario Poirier - 回复
添加评论
浏览统计数据:
过去 24 小时: 21
过去 7 天: 115
过去 30 天: 548
总计 51,419
