简介
This guide will show you the process to disassemble the device and replace the motherboard.
你所需要的
Open the latch that covers the charging port.
Remove the black sticker, then remove the screw with the indicated screwdriver.
Take the plastic opening tool, and run it down the side of the remote to pop the case open.
Detach the white clamp in order to partially disconnect the case from the motherboard.
结论
