跳转到主内容
Logitech Harmony Touch Buttons Replacement
你所需要的
  1. Logitech Harmony Touch Buttons Replacement, Buttons: 步骤 1 中的图像 1,3 Logitech Harmony Touch Buttons Replacement, Buttons: 步骤 1 中的图像 2,3 Logitech Harmony Touch Buttons Replacement, Buttons: 步骤 1 中的图像 3,3
    • Open the latch that accesses the charging port.
    • Remove the black sticker and the screw with the Phillips #0 Screwdriver.
    • Take the plastic opening tool and run it down the side of the remote to open the case.
    • While doing this step, three wires connect the two pieces, be sure not to rip them out.
    • Detach the white clamp to disconnect the case from the motherboard partially.
  2. Logitech Harmony Touch Buttons Replacement: 步骤 2 中的图像 1,3 Logitech Harmony Touch Buttons Replacement: 步骤 2 中的图像 2,3 Logitech Harmony Touch Buttons Replacement: 步骤 2 中的图像 3,3
    • Peel back the thin yellow plastic film.
    • Detach the clip found underneath the film.
    • Remove the screws that connect the motherboard to the case with the Phillips #0 Screwdriver.
  3. Logitech Harmony Touch Buttons Replacement: 步骤 3 中的图像 1,3 Logitech Harmony Touch Buttons Replacement: 步骤 3 中的图像 2,3 Logitech Harmony Touch Buttons Replacement: 步骤 3 中的图像 3,3
    • Next, carefully remove the motherboard from the top piece of the case.
    • The motherboard is connected to the bottom part of the case.
    • You should now be able to access all the buttons and remove them from the case.
  4. Logitech Harmony Touch Buttons Replacement: 步骤 4 中的图像 1,2 Logitech Harmony Touch Buttons Replacement: 步骤 4 中的图像 2,2
    • Remove the buttons from the case.
结论
另外一个人完成了本指南。
团队
USF Tampa, Team S4-G2, Eyestone Fall 2017 USF Tampa, Team S4-G2, Eyestone Fall 2017 的会员
USFT-EYESTONE-F17S4G2
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 22
总计 1,305
