跳转到主内容
Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement
你所需要的
  1. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement, Back Panel: 步骤 1 中的图像 1,2 Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Turn keyboard over to the backside.
  2. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: 步骤 2 中的图像 1,3 Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: 步骤 2 中的图像 2,3 Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: 步骤 2 中的图像 3,3
    • Press and slide up on the upper battery latch, using both thumbs.
  3. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: 步骤 3 中的图像 1,1
    • Remove the two AA batteries and set them aside.
  4. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: 步骤 4 中的图像 1,2 Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: 步骤 4 中的图像 2,2
    • Unscrew all five 4.0 mm screws, using Phillips #1 screwdriver.
  5. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: 步骤 5 中的图像 1,2 Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: 步骤 5 中的图像 2,2
    • Peel off the center sticker to reveal two hidden 4.0 mm screws.
    • Unscrew these two screws with a Phillips #1 screwdriver.
  6. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: 步骤 6 中的图像 1,3 Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: 步骤 6 中的图像 2,3 Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: 步骤 6 中的图像 3,3
    • Lift both top left and top right rubber stickers halfway, using the sharp end of the plastic spudger.
    • Unscrew a total of two 4.0 mm screws, under the rubber stickers, using a Phillips #1 screwdriver.
  7. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: 步骤 7 中的图像 1,2 Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: 步骤 7 中的图像 2,2
    • Unscrew the top center 4.0 mm screw, in the battery compartment, using the Phillips #1 screwdriver.
    • Now, you should have a total of ten 4.0 mm screws set aside.
  8. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: 步骤 8 中的图像 1,3 Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: 步骤 8 中的图像 2,3 Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: 步骤 8 中的图像 3,3
    • Wedge the flat end of the spudger between the back panel and front panel.
    • Slide the flat end of the spudger from right to left to pry the two panels apart.
  9. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: 步骤 9 中的图像 1,3 Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: 步骤 9 中的图像 2,3 Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: 步骤 9 中的图像 3,3
    • Separate the back panel from the front panel completely, using both hands.
    • A white ribbon flex cable will remain connected to both panels.
    • Pull the panels apart slowly and gently, or the white ribbon flex cable may be unsafely removed.
  10. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement, Touchpad Printed Circuit Board (PCB): 步骤 10 中的图像 1,3 Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement, Touchpad Printed Circuit Board (PCB): 步骤 10 中的图像 2,3 Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement, Touchpad Printed Circuit Board (PCB): 步骤 10 中的图像 3,3
    • Lift up and pull off the track pad’s left and right clickers.
    • Use caution while lifting, lift slowly with slight pressure.
  11. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: 步骤 11 中的图像 1,3 Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: 步骤 11 中的图像 2,3 Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: 步骤 11 中的图像 3,3
    • Grip the lower end of the ribbon flex cable (white band) using your thumb and index finger.
    • Then slide the strip out toward yourself in a scooping motion.
    • Now, you should have two completely separated panel pieces.
  12. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: 步骤 12 中的图像 1,1
    • Flip the front panel over so the front side faces up, and rotate so the keys appear upside down.
    • Lift the upper-right corner of the sensor sticker using the sharp end of the spudger and your index finger.
  13. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: 步骤 13 中的图像 1,3 Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: 步骤 13 中的图像 2,3 Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: 步骤 13 中的图像 3,3
    • Peel the sticker off by pinching the sticker corner using your index finger and thumb.
  14. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: 步骤 14 中的图像 1,2 Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: 步骤 14 中的图像 2,2
    • Rotate the front panel around so the keys appear right-side up.
    • Wedge the flat-head metal spudger under the PCB's bottom-right corner.
    • Wedge and slide the spudger along the right side to reach the upper-right corner.
  15. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: 步骤 15 中的图像 1,3 Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: 步骤 15 中的图像 2,3 Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: 步骤 15 中的图像 3,3
    • Wedge the flat-head metal spudger under the PCB's bottom-left corner.
    • Wedge and slide the spudger along the bottom side to reach the bottom-right corner.
  16. Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: 步骤 16 中的图像 1,3 Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: 步骤 16 中的图像 2,3 Logitech Harmony Smart Keyboard Touchpad Printed Circuit Board (PCB) Replacement: 步骤 16 中的图像 3,3
    • Slide and nudge the spudger upward underneath the PCB.
    • Wiggle and lift up the PCB with your thumb as you nudge the spudger up to release the PCB.
结论
Edwin Aguilar
于09/11/17注册
143 声望
撰写一个指南
团队
CSU Fullerton, Team S1-G2, Bruce Fall 2017 CSU Fullerton, Team S1-G2, Bruce Fall 2017 的会员
CSUF-BRUCE-F17S1G2
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 18
总计 1,143
