跳转到主内容
Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement
你所需要的
  1. Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement, Back Panel: 步骤 1 中的图像 1,2 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Turn keyboard over to the backside.
  2. Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 步骤 2 中的图像 1,3 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 步骤 2 中的图像 2,3 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 步骤 2 中的图像 3,3
    • Press and slide up on the upper battery latch, using both thumbs.
  3. Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 步骤 3 中的图像 1,1
    • Remove the two AA batteries and set them aside.
  4. Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 步骤 4 中的图像 1,2 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 步骤 4 中的图像 2,2
    • Unscrew all five 4.0 mm screws, using Phillips #1 screwdriver.
  5. Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 步骤 5 中的图像 1,2 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 步骤 5 中的图像 2,2
    • Peel off the center sticker to reveal two hidden 4.0 mm screws.
    • Unscrew these two screws with a Phillips #1 screwdriver.
  6. Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 步骤 6 中的图像 1,3 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 步骤 6 中的图像 2,3 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 步骤 6 中的图像 3,3
    • Lift both top left and top right rubber stickers halfway, using the sharp end of the plastic spudger.
    • Unscrew a total of two 4.0 mm screws, under the rubber stickers, using a Phillips #1 screwdriver.
  7. Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 步骤 7 中的图像 1,2 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 步骤 7 中的图像 2,2
    • Unscrew the top center 4.0 mm screw, in the battery compartment, using the Phillips #1 screwdriver.
    • Now, you should have a total of ten 4.0 mm screws set aside.
  8. Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 步骤 8 中的图像 1,3 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 步骤 8 中的图像 2,3 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 步骤 8 中的图像 3,3
    • Wedge the flat end of the spudger between the back panel and front panel.
    • Slide the flat end of the spudger from right to left to pry the two panels apart.
  9. Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 步骤 9 中的图像 1,3 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 步骤 9 中的图像 2,3 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 步骤 9 中的图像 3,3
    • Separate the back panel from the front panel completely, using both hands.
    • A white ribbon flex cable will remain connected to both panels.
    • Pull the panels apart slowly and gently, or the white ribbon flex cable may be unsafely removed.
  10. Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement, Ribbon Flex Cable: 步骤 10 中的图像 1,3 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement, Ribbon Flex Cable: 步骤 10 中的图像 2,3 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement, Ribbon Flex Cable: 步骤 10 中的图像 3,3
    • Grip the lower end of the ribbon flex cable (white band) using your thumb and index finger.
    • Then slide the strip out toward yourself in a scooping motion.
    • Now, you should have two completely separated panel pieces.
  11. Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 步骤 11 中的图像 1,3 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 步骤 11 中的图像 2,3 Logitech Harmony Smart Keyboard Ribbon Flex Cable Replacement: 步骤 11 中的图像 3,3
    • Grip the other lower end of the ribbon flex cable using your thumb and index finger.
    • Gently slide the cable up and out of the green card.
结论
Hayley Nichols
于09/05/17注册
525 声望
创作了4篇指南
团队
CSU Fullerton, Team S1-G2, Bruce Fall 2017 CSU Fullerton, Team S1-G2, Bruce Fall 2017 的会员
CSUF-BRUCE-F17S1G2
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 15
总计 746
