跳转到主内容
Logitech Harmony Companion Remote Motherboard Replacement
你所需要的
  1. Logitech Harmony Companion Remote Motherboard Replacement, Remote Battery: 步骤 1 中的图像 1,1
    • Hold the remote with the Logitech label toward you.
  2. Logitech Harmony Companion Remote Motherboard Replacement: 步骤 2 中的图像 1,1
    • Push the battery cover upward.
  3. Logitech Harmony Companion Remote Motherboard Replacement: 步骤 3 中的图像 1,3 Logitech Harmony Companion Remote Motherboard Replacement: 步骤 3 中的图像 2,3 Logitech Harmony Companion Remote Motherboard Replacement: 步骤 3 中的图像 3,3
    • Use your finger to lift the battery out of the compartment.
    • When the battery has lifted, push it up to remove it.
  4. Logitech Harmony Companion Remote Motherboard Replacement, Remote Motherboard: 步骤 4 中的图像 1,2 Logitech Harmony Companion Remote Motherboard Replacement, Remote Motherboard: 步骤 4 中的图像 2,2
    • Remove the two 5.0 mm Phillips #0 screws.
  5. Logitech Harmony Companion Remote Motherboard Replacement: 步骤 5 中的图像 1,2 Logitech Harmony Companion Remote Motherboard Replacement: 步骤 5 中的图像 2,2
    • Use the plastic opening tool to pry open the back cover of the remote.
    • It is recommended to have the point of the opening tool facing the back of the remote.
    • Insert the opening tool on each side of the bottom of the remote, and pull up until you hear the cover click open.
    • Pry the back cover off by sliding the plastic opening tool down each side.
  6. Logitech Harmony Companion Remote Motherboard Replacement: 步骤 6 中的图像 1,2 Logitech Harmony Companion Remote Motherboard Replacement: 步骤 6 中的图像 2,2
    • Use the plastic opening tool to remove the motherboard.
结论
6等其他人完成本指南。
Cassidy Wardlow
于09/28/17注册
716 声望
创作了4篇指南
团队
USF Tampa, Team S1-G3, Nance Fall 2017 USF Tampa, Team S1-G3, Nance Fall 2017 的会员
USFT-NANCE-F17S1G3
3 名成员
创作了4篇指南
1指南评论
Any source on that motherboard? I've got two dead buttons and replacement remotes are expensive and hard to come by.
Karl Wooster - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 69
总计 7,335
