跳转到主内容
Logitech Harmony Companion Harmony Hub Motherboard Replacement
你所需要的
  1. Logitech Harmony Companion Harmony Hub Motherboard Replacement, Harmony Hub Motherboard: 步骤 1 中的图像 1,2 Logitech Harmony Companion Harmony Hub Motherboard Replacement, Harmony Hub Motherboard: 步骤 1 中的图像 2,2
    • Remove the non-slip rubber pads on the bottom of the Harmony Hub.
  2. Logitech Harmony Companion Harmony Hub Motherboard Replacement: 步骤 2 中的图像 1,2 Logitech Harmony Companion Harmony Hub Motherboard Replacement: 步骤 2 中的图像 2,2
    • Unscrew the four 6.0 mm Phillips #0 screws.
  3. Logitech Harmony Companion Harmony Hub Motherboard Replacement: 步骤 3 中的图像 1,1
    • Insert the metal opening tool in the slit by the sensor.
    • Carefully separate the Harmony Hub cover from the base.
    • The metal opening tool could damage the device, so use with care.
  4. Logitech Harmony Companion Harmony Hub Motherboard Replacement: 步骤 4 中的图像 1,2 Logitech Harmony Companion Harmony Hub Motherboard Replacement: 步骤 4 中的图像 2,2
    • Unscrew the 2.0 mm Phillips #0 at the bottom right of the motherboard.
    • Unscrew the 4.0 mm Phillips #0 at the top left of the motherboard.
  5. Logitech Harmony Companion Harmony Hub Motherboard Replacement: 步骤 5 中的图像 1,3 Logitech Harmony Companion Harmony Hub Motherboard Replacement: 步骤 5 中的图像 2,3 Logitech Harmony Companion Harmony Hub Motherboard Replacement: 步骤 5 中的图像 3,3
    • Face the Harmony Hub base so the sensor is facing out.
    • Insert the plastic opening tool behind the motherboard on the gold section, which is to the right of the sensor.
    • Lift until you hear a click.
结论
Cassidy Wardlow
于09/28/17注册
662 声望
创作了4篇指南
团队
USF Tampa, Team S1-G3, Nance Fall 2017 USF Tampa, Team S1-G3, Nance Fall 2017 的会员
USFT-NANCE-F17S1G3
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 494
