跳转到主内容
Logitech Harmony 950 Motherboard Replacement
你所需要的
  1. Logitech Harmony 950 Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 Logitech Harmony 950 Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure the remote control is powered off before starting.
    • Use the Opening Tool to open the port cover at the bottom of the remote control.
    • Bend the cover back to gain easy access to the screws.
  2. Logitech Harmony 950 Motherboard Replacement: 步骤 2 中的图像 1,3 Logitech Harmony 950 Motherboard Replacement: 步骤 2 中的图像 2,3 Logitech Harmony 950 Motherboard Replacement: 步骤 2 中的图像 3,3
    • Use the Phillips #0 Screwdriver to remove the (2) two 6mm screws.
    • Pull the bottom cover off of the remote control.
  3. Logitech Harmony 950 Motherboard Replacement: 步骤 3 中的图像 1,3 Logitech Harmony 950 Motherboard Replacement: 步骤 3 中的图像 2,3 Logitech Harmony 950 Motherboard Replacement: 步骤 3 中的图像 3,3
    • Use the Phillips #1 Screwdriver to remove the (2) two 6mm screws.
    • There should be a gap on each side to fit the Opening Tool. Use the Opening Tool to open the back cover (Soft Touch cover) using the gap.
  4. Logitech Harmony 950 Motherboard Replacement: 步骤 4 中的图像 1,3 Logitech Harmony 950 Motherboard Replacement: 步骤 4 中的图像 2,3 Logitech Harmony 950 Motherboard Replacement: 步骤 4 中的图像 3,3
    • Use the Opening Tool to lift the battery out of the case.
    • Gently pull the cable out of the socket to unplug the battery.
    • Be careful not to damage any part of the remote when pulling the cable out.
  5. Logitech Harmony 950 Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,3 Logitech Harmony 950 Motherboard Replacement, Motherboard: 步骤 5 中的图像 2,3 Logitech Harmony 950 Motherboard Replacement, Motherboard: 步骤 5 中的图像 3,3
    • Use the Phillips #0 screwdriver to remove the (3) three 6mm screws.
    • Push the opening tool into the gap along the side of the remote, then slide it across until you hear clicking sounds.
    • You need to repeat this process for both sides of the remote.
  6. Logitech Harmony 950 Motherboard Replacement: 步骤 6 中的图像 1,3 Logitech Harmony 950 Motherboard Replacement: 步骤 6 中的图像 2,3 Logitech Harmony 950 Motherboard Replacement: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    $3.99
    • Carefully remove the back cover and place it next to the remote. Be careful not to detach the wire during this process.
    • Use the angled Tweezers to carefully pull the white cable end off of the remote and disconnect it.
  7. Logitech Harmony 950 Motherboard Replacement: 步骤 7 中的图像 1,3 Logitech Harmony 950 Motherboard Replacement: 步骤 7 中的图像 2,3 Logitech Harmony 950 Motherboard Replacement: 步骤 7 中的图像 3,3
    • Use the Phillips #0 screwdriver to remove the (5) five 6mm screws.
    • Be careful not to detach the pink wires when removing the gold charging conductors.
  8. Logitech Harmony 950 Motherboard Replacement: 步骤 8 中的图像 1,3 Logitech Harmony 950 Motherboard Replacement: 步骤 8 中的图像 2,3 Logitech Harmony 950 Motherboard Replacement: 步骤 8 中的图像 3,3
    • Remove the black tape to access the cable underneath.
    • Use the Angled Tweezers to lift the black lock.
    • Slide the yellow cable to disconnect it from the circuit board.
  9. Logitech Harmony 950 Motherboard Replacement: 步骤 9 中的图像 1,2 Logitech Harmony 950 Motherboard Replacement: 步骤 9 中的图像 2,2
    • Pull the circuit board off of the remote from the bottom, and lift up to detach it from the cover.
结论
2等其他人完成本指南。
Blake Sanborn
于09/26/17注册
589 声望
创作了3篇指南
团队
USF Tampa, Team S2-G2, Passmore Fall 2017 USF Tampa, Team S2-G2, Passmore Fall 2017 的会员
USFT-PASSMORE-F17S2G2
4 名成员
创作了7篇指南
3指南评论
How replace A Mitsubishi Remote Control
عبدالعزيز المناعي - 回复
How replace A Mitsubishi Remote Control ?
Thanks
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 79
总计 3,790
