简介
If the buttons on the keypad are not responsive, use this guide to replace the keypad.
你所需要的
Use the Opening Tool to open the port cover at the bottom of the remote control.
Bend the cover back to gain easy access to the screws.
Use the J0 Philips Head Screwdriver to remove the three 6mm screws.
Push the opening tool into the gap along the side of the remote, then slide it across until you hear clicking sounds.
在这个步骤中使用的工具:Tweezers$3.99
Use the angled tweezers to carefully pull the white cable end off of the remote and disconnect it.
4等其他人完成本指南。
4指南评论
And the replacements parts are purchased from where?
Fruit juice or something sticky was on the keys so had to dismantle, as the keys were hard to press. it seemed just taking it apart fixed it, no cleaning needed. But still took almost an hour to completely dismantle and reassemble.
Some feedback on the guide. Once you access the PCB, and you need to remove the gold charging conductors at the bottom. Mine didn't come out, they both seem hooked in. So in the end I left them in and wiggled the PCB out instead. I think you might need to break the small plastic pits that hold in the charging conductors .
Just a smaller comment - step 7 picture 1 shows the position of the three screws. The one in the middle on the PCB is not pictured correctly.
