跳转到主内容
Logitech Harmony 900 Motherboard Replacement
你所需要的
  1. Logitech Harmony 900 Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 Logitech Harmony 900 Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Press the oval shaped button on the lower back of the remote to release the battery cover.
    • While pressing the button, remove the cover.
  2. Logitech Harmony 900 Motherboard Replacement: 步骤 2 中的图像 1,2 Logitech Harmony 900 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Push the battery in, pull it up, and slide it out.
  3. Logitech Harmony 900 Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,1
    • Using tweezers, peel off the sticker located under the battery cover to reveal two screws.
  4. Logitech Harmony 900 Motherboard Replacement: 步骤 4 中的图像 1,2 Logitech Harmony 900 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Locate and unscrew the four 50mm screws using the Philips #0 screwdriver.
  5. Logitech Harmony 900 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Use a credit card to pry the black, plastic, back cover off of the device.
    • You may need to get the process started with a metal prying tool before you start using the credit card.
  6. Logitech Harmony 900 Motherboard Replacement: 步骤 6 中的图像 1,2 Logitech Harmony 900 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Locate the three 50mm screws on the back of the remote and remove them using the Phillips #0 screwdriver.
  7. Logitech Harmony 900 Motherboard Replacement: 步骤 7 中的图像 1,2 Logitech Harmony 900 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Pry the black, front face of the remote from the back silver part by inserting a credit card in between and sliding down.
    • Again, you may need to use a metal prying tool to get the separation started.
  8. Logitech Harmony 900 Motherboard Replacement: 步骤 8 中的图像 1,2 Logitech Harmony 900 Motherboard Replacement: 步骤 8 中的图像 2,2
    • When you look at the circuit board, you should see a ribbon attaching the board to the plastic casing.
    • A little lever is holding the ribbon in place. Lift the lever with your nail or a 2.5mm flat-head screwdriver. Move the ribbon away from the circuit board.
  9. Logitech Harmony 900 Motherboard Replacement: 步骤 9 中的图像 1,2 Logitech Harmony 900 Motherboard Replacement: 步骤 9 中的图像 2,2
    • Using the Philips #0 screwdriver, remove the three 50mm screws from the circuit board.
  10. Logitech Harmony 900 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Using your hands, carefully separate the motherboard from the rest of the remote.
结论
To reassemble, follow the steps in reverse order.
John Adams
于09/25/17注册
116 声望
撰写一个指南
团队
USF Tampa, Team S4-G5, Eyestone Fall 2017 USF Tampa, Team S4-G5, Eyestone Fall 2017 的会员
USFT-EYESTONE-F17S4G5
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 5
总计 556
