跳转到主内容
加入维修社区 - 创建账户
Logitech Harmony 900 Button Pad Replacement
你所需要的
    1. Logitech Harmony 900 Button Pad Replacement, Battery: 步骤 1 中的图像 1,2 Logitech Harmony 900 Button Pad Replacement, Battery: 步骤 1 中的图像 2,2
      • Press the oval shaped button on the lower back of the remote to release the battery cover.
      • While pressing the button, remove the cover.
      询问修复机器人
      添加评论
    2. Logitech Harmony 900 Button Pad Replacement: 步骤 2 中的图像 1,2 Logitech Harmony 900 Button Pad Replacement: 步骤 2 中的图像 2,2
      • Push the battery in, pull it up, and slide it out.
      询问修复机器人
      添加评论
    1. Logitech Harmony 900 Button Pad Replacement, Motherboard: 步骤 3 中的图像 1,1
      在这个步骤中使用的工具:
      • Using tweezers, peel off the sticker located under the battery cover to reveal two screws.
      询问修复机器人
      添加评论
    2. Logitech Harmony 900 Button Pad Replacement: 步骤 4 中的图像 1,2 Logitech Harmony 900 Button Pad Replacement: 步骤 4 中的图像 2,2
      • Locate and unscrew the four 50mm screws using the Philips #0 screwdriver.
      询问修复机器人
      添加评论
    3. Logitech Harmony 900 Button Pad Replacement: 步骤 5 中的图像 1,1
      • Use a credit card to pry the black, plastic, back cover off of the device.
      • You may need to get the process started with a metal prying tool before you start using the credit card.
      询问修复机器人
      添加评论
    4. Logitech Harmony 900 Button Pad Replacement: 步骤 6 中的图像 1,2 Logitech Harmony 900 Button Pad Replacement: 步骤 6 中的图像 2,2
      • Locate the three 50mm screws on the back of the remote and remove them using the Phillips #0 screwdriver.
      询问修复机器人
      添加评论
    5. Logitech Harmony 900 Button Pad Replacement: 步骤 7 中的图像 1,2 Logitech Harmony 900 Button Pad Replacement: 步骤 7 中的图像 2,2
      • Pry the black, front face of the remote from the back silver part by inserting a credit card in between and sliding down.
      • Again, you may need to use a metal prying tool to get the separation started.
      询问修复机器人
      添加评论
    6. Logitech Harmony 900 Button Pad Replacement: 步骤 8 中的图像 1,2 Logitech Harmony 900 Button Pad Replacement: 步骤 8 中的图像 2,2
      • When you look at the circuit board, you should see a ribbon attaching the board to the plastic casing.
      • A little lever is holding the ribbon in place. Lift the lever with your nail or a 2.5mm flat-head screwdriver. Move the ribbon away from the circuit board.
      询问修复机器人
      添加评论
    7. Logitech Harmony 900 Button Pad Replacement: 步骤 9 中的图像 1,2 Logitech Harmony 900 Button Pad Replacement: 步骤 9 中的图像 2,2
      • Using the Philips #0 screwdriver, remove the three 50mm screws from the circuit board.
      询问修复机器人
      添加评论
    8. Logitech Harmony 900 Button Pad Replacement: 步骤 10 中的图像 1,1
      • Using your hands, carefully separate the motherboard from the rest of the remote.
      询问修复机器人
      添加评论
    1. Logitech Harmony 900 Button Pad Replacement, Button Pad: 步骤 11 中的图像 1,2 Logitech Harmony 900 Button Pad Replacement, Button Pad: 步骤 11 中的图像 2,2
      • Peel off the button pads from the device frame.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Tyler Hanks
于09/25/17注册
442 声望
创作了3篇指南
团队
USF Tampa, Team S4-G5, Eyestone Fall 2017 USF Tampa, Team S4-G5, Eyestone Fall 2017 的会员
USFT-EYESTONE-F17S4G5
4 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 29
总计 1,103
