跳转到主内容
Logitech Harmony 650 Case Replacement
你所需要的
  1. Logitech Harmony 650 Case Replacement, Case: 步骤 1 中的图像 1,2 Logitech Harmony 650 Case Replacement, Case: 步骤 1 中的图像 2,2
    • Remove the battery cover by applying pressure to the indented area and pushing the cover toward the rear of the device.
  2. Logitech Harmony 650 Case Replacement: 步骤 2 中的图像 1,1
    • Remove the batteries using the silver pull tab.
  3. Logitech Harmony 650 Case Replacement: 步骤 3 中的图像 1,1
    • Using a J000 Philips head screwdriver remove the four 5mm screws around the rim of the battery chamber.
  4. Logitech Harmony 650 Case Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Remove the small plastic cover beneath the plastic LED housing by using a 3.0 flathead screwdriver and a spudger to pry it off. It is glued to the case. If you are having trouble removing it try applying some heat to loosen the glue.
  5. Logitech Harmony 650 Case Replacement: 步骤 5 中的图像 1,1
    • Remove the two 5mm screws located underneath the cover using a J000 Philips screwdriver bit.
  6. Logitech Harmony 650 Case Replacement: 步骤 6 中的图像 1,2 Logitech Harmony 650 Case Replacement: 步骤 6 中的图像 2,2
    • Using a plastic opening tool, pry the case off starting from the top of the device (nearest the transmitter). There are 3 tabs along the side of the case and one at the back.
    • The top led protector plastic cover will also be freed once back is removed.
  7. Logitech Harmony 650 Case Replacement: 步骤 7 中的图像 1,1
    • Remove the rear cover.
结论
5等其他人完成本指南。
1指南评论
Thanks for the fix. Now I can get on replacing the corroded battery contacts. Many thanks.
Kevin Bonney - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 23
总计 3,393
