跳转到主内容
Logitech Harmony 300 Batteries Replacement
你所需要的
  1. Logitech Harmony 300 Batteries  Replacement, Identifying the Battery Housing: 步骤 1 中的图像 1,1
    • On the back bottom of the controller, a housing holds the batteries that are used to power the controller.
  2. Logitech Harmony 300 Batteries  Replacement, Removing the Battery Cap: 步骤 2 中的图像 1,1
    • Place a finger on the top of the cap on the indent. While holding the controller with the other hand, press firmly towards the bottom of the controller to loosen the cap.
    • Once the cap is loosen, simply lift the cap out to reveal the batteries.
  3. Logitech Harmony 300 Batteries  Replacement, The Batteries: 步骤 3 中的图像 1,2 Logitech Harmony 300 Batteries  Replacement, The Batteries: 步骤 3 中的图像 2,2
    • Carefully pull the black tap to remove the batteries from the battery housing. When inserting new batteries, be aware of the correct orientation.
结论
另外一个人完成了本指南。
团队
USF Tampa, Team 1-29, Donnelly Fall 2014 USF Tampa, Team 1-29, Donnelly Fall 2014 的会员
USFT-DONNELLY-F14S1G29
1 名成员
创作了1篇指南
5条评论
i bought Harmony 350, and it's imposibble to open this cover, I tried to open this cover for few hours wihout luck, my fingers hurt. Return this crap to shop, I have also Harmony 700 which in it cover open easy.
peter.mac83 - 回复
This instruction is USELESS the catch is too strong! Note all the other questions about the enclosure.
Errol - 回复
it’s impossible !!!
Pascal jade - 回复
I agree with the other comments. I’ll keep trying, but so far after 10 minutes I still can’t get the cover to budge.
Barry Boehm - 回复
pefI too found the battery cover impossible to remove “by hand”. I used the clear plastic package as a cradle for the device,
then used a flat-blade screwdriver applied to the indent where you are meant to push by hand, and pushed hard at about
about a 45° angle. Finally got it open! I filed off a bit of the hook on the cover latch so hopfully it will be easier next time.
Dave Davy - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 19
总计 2,257
